Softcam for channels on Sirius 4,8ESatellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex. | |
| Member Join Date: 15-10-2008 Location: Stockholm
My System: DM 7000S Project Gemini 4.40 Nabilosat Darkstar II |
Hello. I have a dreambox 7000. I've been experimening with keys that are automatically downloadable in the image nabilo darkstar 2. I get only TET channel (Sirius 5E) to work. Could someone please tell me if there's´any chance to get the "SVT" and "DR 1" , "DR 2", "NRK 1" (the nordic "free" channels) via somekind of softcam? | ||
| Specialist Contributor Join Date: 16-03-2005 Location: Belgium
My System: Dreambox with PLi-Emerald 1.09 image, Matrix revolution CAS, newcamd emu, movable dish 0.85 m, very happy indeed | no chance, they're locked in Viacces/NDS. | ||
My System: DM 7000S Project Gemini 4.40 Nabilosat Darkstar II | | ||
My System: Dreambox with PLi-Emerald 1.09 image, Matrix revolution CAS, newcamd emu, movable dish 0.85 m, very happy indeed | scam ? Viasat ? which channels are you getting ? | ||
| | #5 | ||
| | #6 | ||
My System: Dreambox with PLi-Emerald 1.09 image, Matrix revolution CAS, newcamd emu, movable dish 0.85 m, very happy indeed | those channels on Sirius are all marked "videoguard" by Lyngsat - sure you aren't using cardsharing ? NDS encryption isn't broken as far as I know. | ||
| | #7 | ||
| | #8 | ||
| Manic Midlander Moderator Join Date: 24-09-2006 Location: West Midlands. UK
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | Thats strange i'm getting nob all with SCAM ![]() Links are allowed aslong as they are not live ones. Just put _ infront of it ![]() I would be interested in seeing this link of yours so i can confirm if what you are saying holds any water ![]() ![]() Nano | ||
Sanity is nothing more than an excuse to be boring <<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>> <<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>> <<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>> | |||
| | #9 | |||
My System: DM 7000S Project Gemini 4.40 Nabilosat Darkstar II | What did you mean? You get the channels? U have to wait for a few second (5-10) on the channel before picture comes. allright i post the link again for everybody: _http://colibri.net63.net/Kryptoanalyse_des_Premiere_NDS_Verschluesselungssy stem.zip Im running scam in gemini project 4.40 (Dm 7000). I would prefer to run on nabilosat darkstar II instead but cant get any scam version to install on it.. do you have any clues? When trying to install other E1 scam's i get "this is not a valid nabilo pack" | |||
| | #10 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | I did see an Iranian lad saying he could get the soft encrypted NDS channels open just after the Hotbird 10 tests went on air earlier in the year. He was using a plug in for a pc card. | ||
| | #11 | ||
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | Well that link just points to some German Guff about Premiere's NDS setup I'm just going to test with SCAM and will report back later this evening | ||
| | #12 | |||
My System: DM 7000S Project Gemini 4.40 Nabilosat Darkstar II | The thing about these channels are that if you own a viasat box, you can receieve the channels for free, without any card. But u have to call viasat to tell them the boxid and your ID-number and they will somehow unlock it for you. I guess scam might be emulating such an open viasat box idkey..? | |||
| | #13 | ||
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | I tried earlier using SCAM 3.29a, which version are you using. Also do you have a config file that you can post up? ![]() Nano | ||
| | #14 | |||
My System: DM 7000S Project Gemini 4.40 Nabilosat Darkstar II | If you get it to work on nabilosat E1 please let me know. | |||
| | #15 | ||
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | If it works the same as CCcam all you will need to do is copy the newer SCAM file into Var/Bin and it should work ![]() It will need to have the same file name as the version already installed | ||
| | #16 | ||
| | #17 | ||
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | Looks like its an Enigma2 file, that may have something to do with it | ||
| | #18 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | | ||
| | #19 | ||
| | #20 | ||
| | #21 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Hmm VERY interesting indeed. Working fine on scam3.52/ronald-cs installed via the blue button on Gemini See screenshot - Ethernet cable pulled out of DB for accompanying pic of SVT1 to make sure nothing is coming in via the net. DB 7020 | ||
| | #22 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Good to see Sweden still uses in vision continuity announcers | ||
| | #23 | |||
My System: DM 7000S Project Gemini 4.40 Nabilosat Darkstar II | So, now please help me get this running in Nabilosat Darkstar II (E1)... | |||
| | #25 | ||
| channels, keys, sirius, softcam |
