Dragon Cam & Aston Xena Receivers
Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex.
Old 17-10-2004   #1
Hi everyone.
I have recently programmed my Dragon Loader card using my Dynamite programmer in 6 Mhz Phoenix.
I own an Aston Xena 1700, but the manual does not tell me how to download from the loader card onto the module.
Any ideas?
Lundenwych is offline   Reply With Quote
Old 19-10-2004   #2
artem's Avatar
Talking
Originally Posted by Lundenwych
Hi everyone.
Any ideas?
Hi there, try this advice
You need:
-Smartmouse compatible card programmer
-The dragonload.exe program
-Connect the card programmer to com1 or com2, make sure the programmer is in 6 MHz mode
-Execute "dragonload.exe"
-By pressing the "Settings" button, you can change from com1 to com2
-Press "Connect"
-In the file open dialog that appears, select the firmware you want to load.
-The card will now be loaded.
ALTERNATIVE METHOD
For this method, you need a FUN7 card
Using a suitable program, program the FLASH of the FUN7 card with FUN7LDR.HEX,
and program the EEPROM with predator2XX.bin. Make sure the program you use
handle the large eeprom size of the fun7 card correctly!
END alternative method
Insert the programmed card into the Dragon module. Insert this into a receiver
and turn on the receiver. make sure you are tuned to an FTA channel.
Go to the Common interface menu on the receiver, and select the "Dragon Loader" module.
In the next menu, select "yes, Load module".
Now a menu appears indicating that loading is in progress. To see the actual porgress percentage,
select "refresh". There is no auto-refresh because some receivers had problems with that....
When loading is complete, a menu appears saying "Loading successful". REMOVE the loader
card from the module, and switch off and turn back on the receiver.
artem is offline   Reply With Quote
Old 20-10-2004   #3
Thanks Artem. I'll give that a bash.
aston, cam, dragon, receivers, xena
Similar Threads
diablo cam wolfav Cams and decoders General 0 08-05-2006 04:28 PM
Dragon Cam T24 Cams and decoders General 11 08-06-2005 01:10 AM
Can I do this - use my Nokia 9800 with an Aston CAM and a Canal + spain card. danny The Meeting Place 1 29-03-2004 11:47 PM
Aston 1.03 CAM refinechange Cams and decoders General 3 02-02-2004 11:02 PM
what can i do with aston cam CHEEF Seca/Mediaguard system 3 13-09-2003 09:06 AM
