Infinity USB, which file where?
Thread Tools Display Modes
Old 16-12-2004   #1
tonypowell's Avatar
Question Infinity USB, which file where?
I have downloaded the file predator 231. I have a Fun 7 Dragon Loader card
I know that I have to write "FUN7LDR.HEX" into Flash.
However which file has to be written into "Int EEProm" ( Is it predator231.bin or predator231.dra?) or do I leave it empty?
Similarly for "Ext EEProm" ( Is it predator231.bin or predator231.dra?) or do I leave it empty?
The infinity software seems to read the card as a funcard 2 - is that correct or should I change it? Should I have it 'autodetect" the card?
Hope somebody can help
tonypowell is offline   Reply With Quote
Old 16-12-2004   #2
hi, i have the usb/pheonix one so i´m not sure about just using the usb only. i used the ext eep only which is the dra. but i´ve pasted the how to from the 231 file below.
ALTERNATIVE METHOD
For this method, you need a FUN7 card
Using a suitable program, program the FLASH of the FUN7 card with FUN7LDR.HEX,
and program the EEPROM with predator2XX.bin. Make sure the program you use
handle the large eeprom size of the fun7 card correctly!
END alternative method
rob43 is offline   Reply With Quote
Old 16-12-2004   #3
tonypowell's Avatar
Thanks, I have now worked it out:
1: I need to have it set up as a Fun 7 card, which gives me 4 places to populate.
2: Put the flash file in Flash
3: Split the predatorxxx.dra file into tw parts using a hex editor which will give me predatorxxxeeprom1.bin and predatorxxxeeprom2.bin, or
4:Find a site with them already split such as:
http://www.ucassupport.nl/dragonsupp...h/Software.htm
5: leave the internal eeprom alone, but populate the external 1 and 2 with the eproms
6: Et Voila, Robert is your Father's Uncle.
Old 17-12-2004   #4
thats good news, glad you got it working. btw pred 232 is now out, tps & mv working
Forum Jump
Similar Threads
problems with infinity usb programmer bennykoo2003 Cards & Programmers General 1 08-09-2006 12:16 PM
Matrix Reloaded How To by AHAC rolfw Matrix Reloaded, Revolutions and CAS interface 52 27-12-2005 12:02 PM
New soft ware for Infinity usb Programmer. rabbi Cards & Programmers General 1 07-09-2004 01:05 AM
infinity usb pheonix and titanium fasta Cards & Programmers General 3 24-02-2004 12:21 AM
How to use Infinity USB programmer. T24 Tutorials & How To guides 1 10-10-2003 07:51 PM
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.8.0
