Dragon cam/NDS problemSatellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex. | |
| Regular Member Join Date: 15-10-2005 Location: North Staffordshire England
My System: 60cm dish, dual LNB, Topfield TF5010PVR |
I can hear the teeth sucking, and "Oh no told him so." as I type! ![]() I have loaded a Dragon Cam (with the previous version software) into my Humax9100. All seems well, I can go into setup and input my Sky box number, but (with my Sky card in) it still is unable to decode channels. Any ideas as to what I may be doing wrong please? | ||
| The Following User Says Thank You to John T For This Useful Post: | stepheneabry (12-10-2009) |
| Super Moderator Join Date: 10-12-2004
![]() | Hi John T, most of the time the problem is not getting the serial number correct, but you should still get the basic channels, from the Predator readme file: Important: in order for the Sky UK NDS premium channels to work you need to (apart form subscribing that is..): -Tell your Dragon the serial number of the original Sky box your card is married to. You can find this 10-digit number in the menu of your original Sky box, services->system setup->system details. You need the SERIAL NUMBER (and NOT the viewing card number!) Now go to the menu of you Dragon, settings->NDS Box serial. Here, enter the 10 digit serial number including any leading zeroes. If your NDS card was already inserted into the Dragon, remove and re-insert it after changing the Box Serial. Now you're all set! Failure to set the box serial will result in movie channels and other premium channels not opening. The simplest faults are, having the card inserted incorrectly, should be chip facing upwards. A patched receiver causing problems with the Dragon Cam. If these are not the problems please post back Best wishes Mickha | ||
| The Following User Says Thank You to Mickha For This Useful Post: | shadow28 (16-09-2008) |
| | #3 | |||
I was supplied with the Dragon cam plus Prussian Galaxy5 card. The Dragon needed progamming, being ignorant I sent the Dragon off instead of the card, however that has been programmed with Predator 3.22. So, I enter SYSTEM-STATUS-COMMON INTERFACE-SLOT1-SMART CARD on my Humax 9100. ( I have previously set the NDS Box serial number to the same as on my Sly box settings, which corresponds to the s/n on the box itself) I then get: Smart card unknown 1 --- Not decoding Your statement: "A patched receiver causing problems with the Dragon Cam." does not, I'm afraid, mean anything to me any further help would be appreciated Thanks John | |||
| | #4 | |||
| Regular Member Join Date: 17-10-2005 Location: UK
My System: Humax CI-24 with Dragon Cam combo box canal digital CD Norway card dish:90cm LNB:0.3 1w(thor) /5e (sirius) 30 hispasat comag sl 65(chess sl 35 patch) thompson sky box |
only 3.21 at the moment.... | |||
| | #6 | |||
![]() I did ask the chap who loaded my cam to put the version on that worked with NDS, I've emailed him to see if he can sort me out. If not what other way is there to get regraded? Can I just send my card to someone to get it done? Also is it worth getting a programmer so that I can do any future updates myself? If so which one is recommended? Thanks John | |||
| | #7 | |||
also the card goes up side down in the cam. i did test with sky italy and dragon is working .(official card) | |||
| | #8 | ||
| Member Join Date: 15-08-2008 Location: fundee
My System: big dish and seven receivers | Hei guys and gals looking at getting viasat card 1deg west for champions league football they said i need a 'NDS' approved cam is the dragon cam the one for me thanx Tan | ||
| | #9 | ||
| Member Join Date: 20-02-2008 Location: Malaysia
My System: Newbie |
Hi Micha, I was wondering if you are kind enough to help out (or point us the right direction). Our provider in malaysia (Astro 91.5E) just changed from SECA2 to NDS. We have valid subscription card but was unable to view channels through my T-Rex Cam. Tried both the latest predator 368 & predasaur 226 files.Here's some info on our provider. _http://www.sat-television.com/showthread.php?t=50274 I was hoping to watch using valid subscription card through DVB-S (Twinhan) and T-rex CAM (for scheduled recording, etc) rather than through the original box. I have a Duolab CAS 3 programmer. I hope you are kind enough to point me the right direction. Any help provided is highly appreciated, thank you. | ||
| | #10 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | See this thread http://www.satellites.co.uk/satellit...ox-months.html | ||
| | #11 | ||
| Member Join Date: 18-01-2005
| Realise this is an old topic but not one person seems to have mentioned an important fact. Sky White Cards dont work with Dragon CAM only the older Blue cards.....but the Predator file has to be patched with the correct CAIDs (Conditional Access IDentifier) 0961 for Sly UK Blue cards. You can patch it with the DRA patcher or DragonCrypt or Pred Edit | ||
| cam or nds, dragon, problem |
Similar Threads | ||||
| problem with Dragon and ST550 | seg | X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex | 4 | 10-09-2005 11:18 PM |
| Have a problem MPEG2 DVD conversion | mgharbawy | Computer Discussion | 4 | 21-06-2004 10:02 PM |
| Have a problem with Vision Plus | mgharbawy | Satellite PC Card Receivers & Internet by Satellite | 1 | 15-02-2004 10:47 PM |
| is this a diseqc problem | doggy | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 14 | 05-09-2003 02:44 AM |
| Aston to Diseq poitioner problem | BazelAd | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 4 | 20-08-2003 07:21 PM |
