Predator 3.24 released
Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex.
Old 18-11-2005   #1
My System: next 2000 common interface dargon cam aston cam irdeto cam
PREDATOR 3.24 has been released today.
this is what it says in the read me file
About this version:
For Dragon Module.
Emulation for Irdeto, Nagra, Viaccess, Viaccess2, Seca and Conax , with keyeditor
(check out the "Debug" option in the menu).
Nagra AU
New:
TPSCrypt AES key is now editable.
In debug menu, go to Viyuckses, Viyuckses1, then 55aeae-TPS AES.
Select key0x08-key0x09, and put the AES key in key 08-0 and key 08-1.
Provided AES key was working 18/11.
If u ask me i think releasing another predator 4 the dragon cam is stupid because it doesn't fix the digital+ problem.
proffk is offline   Reply With Quote
Old 18-11-2005   #2
malcolm's Avatar
My System: Sky+ (basic sub) Echostar AD3000IP Dragon Cam Infinity Phoenix Geotrack polar mount 88cm Triax dish Digitalb Supersport
I have lost M*sion channels will loading Predator 3.24 restore them?
Thanks for any replies.
malcolm is offline   Reply With Quote
Old 19-11-2005   #3
Yes, Predator 3/24 has been modified so that it allows you to change the AES key using the Dragon Cams debug option.
Mickha is online now   Reply With Quote
Old 19-11-2005   #4
malcolm's Avatar
Have loaded 3.24 OK and tried the debug option but not sure how much damage I will do if I enter wrong code or press wrong key? Have seen an AES key on another site, do I overwrite the key that is onscreen after selecting 0x08-key0x09 the option? this is all unchartered territory for me.
Thanks, Malcolm
Old 19-11-2005   #5
Hi malcolm,
I've sent you a PM.
Best wishes
Mickha
Old 19-11-2005   #6
jimmyireland35's Avatar
Can some one pm me about this AES key...what does it do etc
jimmyireland
jimmyireland35 is offline   Reply With Quote
Old 20-11-2005   #7
Hi jimmyireland35,
Multivision are currently cahnging the AES key on a regualr basis, at present daily, which means you have to manually enter the new AES key manually to be able to view Multivision, TPS channels are still available so far. This wasn't possible on earlier Predator firmware but 3.24 remedies this and allows us to continue viewing these channels, by inputting the new key, using the Dragons debug option, nalcolm just needed a quick guide on how to do this.
Best wishes
Mickha
Old 24-11-2005   #8
My System: Manhattan ST550
AES key
Hi
I have just recently purchased the Dragon Trex cam with the latest predator release of 3.24 pre installed
This enables me to view TPS and some multivision channels.
Please Can someone explain as to what other channels are available with this patch
Do i need a new AES key to view other channels?
if so. can someone send the latest info to my PM and let me know how to change the key
Newbie
starman3 is offline   Reply With Quote
Old 24-11-2005   #9
malcolm's Avatar
Starman3,
Highlight search in the toolbar, type in 'dragon list' then select the 'Dragon channel list' post.
Malcolm
Old 25-11-2005   #10
sputnick's Avatar
My System: DM7000S, movable dish 1m pointing at 13E, 5E and 4W. The Gemini Project 2.90 Image in Flash. No multi-boot.
k, but still I dont get, in Dragon Cam Predator 3.24 you got this debug option, I found some AES keys, BUT there is 55AEAE : TPS AES and 007C00 : TPS.
Those two fields are pretty much the same inside, which one needs to be updated ? I try both, nothing seems to work. Thanks.
sputnick is offline   Reply With Quote
Old 25-11-2005   #11
sputnick's Avatar
On laulars.com they say about TPS key 3 & 13 are TPS AES key, if I understand right : on Predator 3.24 I open 55AEAE TPS AES, then first line Key 0x08 - 0x09, but then what ? You got fields 08-0 and 09-0 already filled in. Those 03 & 13 keys from laurals.com need to be put in the fields 08-1 and 09-1 or what ?? Thanks.
Old 25-11-2005   #12
sputnick's Avatar
Oh I got it, you just fill in 08-0 and 08-1 as of it was one single field. Ok M*ltiv*on working fun !!!! hehe
Old 25-11-2005   #13
sputnick's Avatar
OK, now next step is to make it work with EMU from Dreambox, but this I'll post in drembox topic, cya.
P.S If i make it work ofcoz lol
Old 25-11-2005   #14
My System: Humax CI-24 with Dragon Cam combo box canal digital CD Norway card dish:90cm LNB:0.3 1w(thor) /5e (sirius) 30 hispasat comag sl 65(chess sl 35 patch) thompson sky box
so you just type the same key both???
Move is offline   Reply With Quote
Old 25-11-2005   #15
sputnick's Avatar
No, no
Here is how it goes :
If you found the right key, it should have 32 digits or may be noted as two lines of 16 digits.
So the first 16 you just type in the line 08-0 and second 16 dogots you fill in line 08-1.
All that under debug, TPS AES 55AEAE, and NOT TPS 007C00
Then do not forget to reste the cam !!!
And all goes perfect, enjoing right now
Old 25-11-2005   #16
No, no
thanks))
Old 18-04-2006   #17
My System: COMPUTER
Predator 3.23 (T REX)
Hi Guy,
Sorry to jump into the discussion this late.
Seems as if I'm still behind as I've just bought the T REX 3.23, but does not open up any channel (i.e. Astra, TPS e.t.c).
Can any one assist me on this? Or do I need to upgrade to 3.24 for it to work with my box(TOPFIELD)?
Thanks,
suya is offline   Reply With Quote
Old 18-04-2006   #18
Mod and septic resident
Channel Hopper's Avatar
You haven't heard of 3.32 then ?
Plenty of channels on Astra, even without a programmed CAM
what were you advised/supplied when you bought a TRex 3.23 , any loader card , any programmer, any guarantee ?
Old 30-08-2008   #19
My System: kaon box. t-rex. dragon.
predator 3.24
hi all where can i download pred 3.24? please helppppppppppppppp.
john1950 is offline   Reply With Quote
Old 30-08-2008   #20
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
That one's got cobwebs on. Doubtful if it'll be of much use (If you can find it).
Predator 368 is the latest one.
Llew is offline   Reply With Quote
Old 31-08-2008   #21
latest predator
hi. what is the latest predator and where can i find it and download it. 31/8/08.
Old 31-08-2008   #22
As Llew said the last Predator released was predator 368, there are known problems with this file and early 2.x versions of the Dragon Cam, but this file currently opens Premiere, Polsat and Digi TV and is AU on all of them.
If you look on the forum you will see The Links Section, which contains a lot of useful links, or if you type predator368, no spaces, into any search engine, you should quickly find it.
The original, unmodified version of the file, is by kinkdink.
Old 01-09-2008   #23
hi. can you tell me where i can find predator 3.24 so i can download it.
Old 01-09-2008   #24
As you can see by the date of the thread Predator 324 was released in November 2005 and so is of no use now.
You require Predator 368.
I have uploaded a copy of the original predator 368 to sendspace for you:
_http://www.sendspace.com/file/5mled8
324, predator, released
Similar Threads
predator 3.10 released jacko X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex 1 14-04-2005 05:40 PM
predator 3.08 released jacko X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex 2 11-04-2005 06:50 PM
Predator 2.23 released Grayarea X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex 0 22-10-2004 05:09 PM
Predator 2.17 released Grayarea Cams and decoders General 2 12-07-2004 11:16 PM
Predator 2.14 released Grayarea Cams and decoders General 2 05-06-2004 03:36 PM
