Anyone Using T-REX on Fortecstar?
Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex.
Old 26-03-2006   #1
My System:
I just bought the latest T-REX CAM and programmed it using the Dragon Loader card. It sort of works!
I was using AL7BAR firmware previously but that wasn't getting updated on the Fortecstar Ultimate so I bought the CAM. On supported channels AL7BAR worked great and displayed the channels quickly.
I have the latest Predator software installed correctly. Some channels work, others (which should) don't and some appear not to work, then they do work!
In these cases the screen says "Scrambled or bad channel" then several minutes later the channel tunes in. Sometimes it's good reception, other times it breaks up, freezes or switches frequently tunes in and out of the channel (loses picture, says "Scrambled or bad channel" then tunes back in again). Some of these are the same channels I was getting without problems on AL7BAR.
Am I doing something wrong? Are there compatibility problems with T-REX and Fortecstar? Is it normal for Predator firmware to take several minutes to tune in and often lose the channel after that?
Any help would be appreciated. Thanks
benbecula33 is offline   Reply With Quote
Old 26-03-2006   #2
My System: 28e, 19e, 13e, 30w
I've got the same set-up: an Ultimate and T-rex (and I bought the T-rex for the exact same reason!) Actually I've got two Ultimates and one of them doesn't even work with the CAM - picture is constantly breaking up. I've tried both CAM slots and it makes no difference. On the other Ultimate I get the same problem with one of the slots and the other works fairly well on some packages/channels and not on others. It's really bad with a Sky viewing card and doesn't even work well with the adult card it comes with.
Both Ultimates were secondhand and I'm pretty sure they're to blame not the T-rex. Unfortunately I don't have another CI receiver to try the CAM in.
FWIW if I go to bed with a scrambled TV or radio channel on you can guarentee I'll wake up to a blank screen!
Skip Channel is offline   Reply With Quote
Old 26-03-2006   #3
My System:
Sky Card
Thanks for the reply. Hopefully someone might know more about what's causing the problems than we do!
I can't work out how to use a Sky card in the T-REX. I've entered the number for the old sky box it belongs to, but it doesn't seem to do anything. The card is for the free channels only, but won't even decode CH4 & CH5, though these work on the Sky box.
How did you get yours working?
Old 26-03-2006   #4
Mines just for the FTV channels only too. Anyway, I know it sounds obvious but I have to ask - did you try putting the card in the other way up? It should go in upside down (ie the chip is facing upwards).
Old 26-03-2006   #5
My System:
Sky Card
Yes, thanks I was putting it in with the contacts on the card facing upwards. Should I get CH4, CH5 etc and should I get the Sky EPG? If not, how do I know if it's working or not?
Old 26-03-2006   #6
You should get Channel 4, Five and Sky Three. You'll only have now and next info for any of these channels though - no full EPG (Sky's system is proprietry).
Old 27-03-2006   #7
My System: fortec star fsci - 5100 ultra reciever. 2 cam slots. 90cm dish titanium 0.2db lnb disceq motor loopthrough to Sky digital box. Dragon Cam v4.1 pred 332 Now a CAS3 owner
I have a dragon cam with the predator software brought it for the same reason as you no updates to the al7bar software.
Apparently there is a compatabilty issue with fortec recievers.
Mine sometimes comes up with bad or scrambled when i channel hop only once in a while though.
Found switching the al7bar software off and only having display timeout up for 5 secs reduced how often it occurs.
nathanvtr is offline   Reply With Quote
Old 01-04-2006   #8
My System:
Could Pansat be the answer?
It looks like there must be a compatibility issue. I had set the AL7BAR software uninstalled and the timeout set to 5 secs already. I changed timeout to 3 secs which has helped a bit more. It must be possible to patch the Fortecstar firmware so it doesn't screw up with a Dragoncam.
I know Fortecstar receivers are compatible with Pansat models, but not sure which models are compatible with which. Perhaps trying the correct Pansat firmware might help?
Old 01-04-2006   #9
My System:
Channel 4
Thanks for the info on the channel guide. I had hoped I would get the Sky one! I still can't get Channels 4 & 5 but I might mess around over the weekend a bit more to see what's wrong here.
Old 01-04-2006   #10
Rob
Super Nutty Mod
Rob's Avatar
My System: Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka !
Hi Lads, Not trying to hi-jack your thread but seeing as you are all experts on Fortecstar receiver's can you tell me if it is possible to "patch" the Fortecstar Lifetime Classic FTA receiver.
It's not for me but someone asked if it's possible to receive the TPS channels from Hotbird, and as I don't have this type of receiver I thought it best to ask the experts.
Rob is offline   Reply With Quote
Old 01-04-2006   #11
My System:
You need a copy of the AL7BAR replacement firmware for the receiver. You will find this easily through any search engine. There are tools which allow you to upload the firmware to your receiver.
Old 02-04-2006   #12
problem is it hasnt been updated for a while and inputting the keys on a daily basis to get channels such as multivision isnt possible as there isnt enough digits on the fortec software for AES keys if i remember correctly.
Old 02-04-2006   #13
Dont know about the pansat compatibility, im guessing your clock doesnt stay correct another al7bar bug. I would put mine back to factory if the software would talk with my box but as of yet havent managed to do it.
Got my other halfs laptop for a bit so may give it a shot later.
Old 02-04-2006   #14
My System: Skystar2 + FortectStar 5100 ultra 85cm motorised
Unhappy Fortec 5100 utra plus
Does not work , unless you eject cam and re-insert after every channel change , this is one frustrating hobby ,bring back the crystal set
tigertail100 is offline   Reply With Quote
Old 03-04-2006   #15
My System:
I tried a Pansat bin in mine and it locked up! Never mind, it's fun experimenting!
Old 14-04-2006   #16
Shouldnt do it after every channel change set your timout to the lowest setting which is 5 secs i think and wait for it to go off screen before you switch channels, i have gone several days sometimes with no problems failing that just turn to one of the full x channels and wait a sec will make the cam re-initialise, saves having to get up eh
Old 29-04-2006   #17
My System: Technomate 7800 Technomate 1500+ super Technomate 7655 Technomate 5500 super Fortec star 5100 ultra lemon 030 ci
Fortec and dragon.
I allso have problems with dragon cam and fortec star. It seems to work on all chanells, but as soon as you put cam in, picture goes very grainy like bad analogue reception.(fortec star 5100 Ultra).
gzappa is offline   Reply With Quote
Old 29-04-2006   #18
Mentally unstable.
Yorks's Avatar
My System: Pretend to know what I'm doing. Only the clever ones rumble me.
...Now he's joined a sat forum, And boy does he borem, When the hind legs off a donkey - he talks
Have you turned off the keycode function on the Fortec?
Life's a bitch ................ and then there's S*y (No change there then)
Wurdoch ist ein Manker. (Mank being a city in the
Austrian Alpine foreland)
Yorks is offline   Reply With Quote
fortecstar, trex
Similar Threads
fortecstar and key 23 ciarank Conax, Cryptoworks, Nagravision, NDS and Others 4 20-02-2006 10:41 AM
Fortecstar. Ultimate problem/Ultra explanation Yorks Digital systems 2 19-04-2005 04:27 PM
Fortecstar Lifetime doesn't boot after uploadin new new boot and firmware jjab Receiver software, international Section 5 27-12-2004 10:53 AM
New Software of fortecstar Lifetime TPS MULTIVISION rukh21 Receiver software, international Section 1 30-11-2004 02:52 PM
fortecstar 5100 Plus+ Al7barCi+ V2,39 0007ta Receiver software, international Section 1 21-09-2004 01:24 AM
