T-Rex camSatellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex. | |
| | #26 | ||
| Member Join Date: 04-01-2007 Location: Bulgaria
My System: HDCI-2000, SS2 | I have just bought a T-Rex super module 4.6. Can someone confirm that you can load a predator file on the T-Rex super module 4.6? Is the T-Rex super module 4.6 backward compatible with the T-Rex 4.1? Thanks | ||
| | #27 | ||
| Super Moderator Join Date: 10-12-2004
![]() | Hi qwertysas, you can load either Predasaur or Predator files on the 4.6 supermodule, but it is best to first load the latest predasaur 208 file and do the security update, for Premiere. Once the update is done you can use any Predator/Predasaur file and this will not affect the security update. Best wishes Mickha | ||
| | #29 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | A good place would be to start here - http://www.duwgati.com/uk/index.htm Llew | ||
| | #30 | ||
| Member Join Date: 02-07-2007 Location: ireland
My System: techomate1600 with trex 4.6 cam |
how do i program a trex cam with a infity unlimited programmer and does any one know where to get the upto date codes | ||
| | #31 | ||
![]() | Ensure you have the latest software for your Infinity programmer, and then start up the software, insert your card, chip face down. If you have a T-Rex supermodule 4.6, you need the latest Predasaur file. If you have the earlier twin cam version you need the latest Predator file. You can find links to these files in the Big Links list: http://www.satellites.co.uk/satellit...lys-big-links/ If you have a Fun Card 7 then choose DragonLoaderCard (AVR), leave the built in loader, and click on the folder icon next to Ext EEprom, and navigate to the required Predasaur/Predator .dra file. Choose option 2, reverse span, and click write. If you have a PIC F84a loader card, choose DragonLoaderCard (PIC), leave the built in loader, and click on the folder icon next to Ext EEprom, and navigate to the required Predasaur/Predator .dra file. Once your card is loaded, follow these rules otherwise you could damage your cam: Tune your receiver to a FTA channel. Turn off your receiver. Insert your programmed loader card into your Cam, chip face up, and if the cam isn't already, insert it in to your receiver. Turn on your receiver. Navigate to the Cams menu and choose yes load cam. Wait until it has finished loading, a message appears telling you the cam is loaded and to remove the loader card. Remove the loader card, and restart your receiver. Your cam should now be updated. If you experience any problems please post back. | ||
| | #32 | ||
My System: techomate1600 with trex 4.6 cam | thanks mickha ive loaded it as you described and it has worked to a certian extent the d+ on astra works fine but primire dosent niether do any of the packages on hotbird i tried the security up date feature and premire work but it knocked the d+ package off do u know of any sites that might have the upto date downloads i need | ||
| | #33 | ||
![]() | The T-Rex 4.6 does not open TPS, only the Diablo Cam does and patched receivers. Carrying out the security update should not have affected D+, go into the cams menu, debug, OhlAladin, on the second page, and D+, and check you have the latest keys. Predasaur 216 is the last Predasaur file, but you can find different versions, with different biss providers, but they are just modified versions of the original file. | ||
| | #35 | ||
![]() | To update biss/dcw keys in a Dragon Cam you need a software editor, the 2 easiest to use are CAID_SHA_Fix and Prededit. You edit the predator358 file using either of these and then load your cam as usual. These keys usually only last a matter of hours, so you have to be quick. | ||
| | #36 | ||
My System: techomate1600 with trex 4.6 cam | thanks again mickha i got most of the bits to work but i think that my main prob now is the reciever its running on old software from 05 and needs upgraded when i do this it should solve all | ||
| | #37 | ||
My System: techomate1600 with trex 4.6 cam | forgot to ask mickha does and of the keys work on any of the hotbird packages with the trex 4.6 the astra ones work fine all except viacess but none of the ones seem to work on hotbird tps did decript for about 15mins but then packed up but that was all | ||
| | #38 | ||
![]() | The only channels the 4.6 can open on hotbird is the SRG Swiss package, providing you have the updated keys, TCM Classic and Cartoon network 10949 V 27500, and the odd channel. It will not open TPS, who change their keys every few minutes so require AU, but there are daily updates for Absat. You are better off on 19E, with Premiere and D+ or 30W for D+ and Cabo. | ||
| | #39 | ||
| Member Join Date: 17-08-2007 Location: england
My System: hotbird satellite with digiquest 8000sci receiver with a t-rex cam and access card |
i have had a t-rex cam for about a year now and i did not buy anything for loading up or upgrade purposes since i know nothing about them. A few weeks ago i was looking on Ebay | ||
| | #40 | ||
![]() | Hi marc1_007, welcome to the forum. If your Cam has Predator 359 loaded on it then you can get a lot of channels open, but not on hotbird 13E. The first thing to check is which version of Predator you have loaded, to do this you need to enter your receivers menu and navigate to the CI slot, here you should see Predator xxx. If you enter this you will see several options, you need to press debug, to be able to manually enter new keys. Most of the open channels can be located in OhlAladin, where you can update the keys to get the following big packages: Premiere and Digital +, on 19.2E. Digital + (Same channels as on 19.2E) and TV Cabo, on Hispasat 30W. To update the keys you need enter the Dec (Decimal) keys. Dec (Decimal) keys are a sequence of 3 numbers 0-9, once inserted the key will show up as hex (Hexadecimal) a combination of 2 letters or numbers, A-E & 0-9. I realise it sounds complicated but once you do it the first time you will see how easy it really is. On Hotbird you can get the SRG Swiss package, only a few channels, and the odd channel like TCM and Cartoon Network. Please post back with any questions, or problems, that you run into, and if you want to progress further in this hobby you might consider getting a Cas 3 + programmer. | ||
| | #41 | ||
My System: hotbird satellite with digiquest 8000sci receiver with a t-rex cam and access card | the key codes have been very helpful they work with a few channels but not the mct channels though the major problem that i have now is that less than 30 secs after a channel has been unlocked it freezes again is that supposed to happen | ||
| | #42 | ||
![]() | I have started moving a few posts from this thread, to their own thread, as it is becoming a little confusing trying to deal with different, non-related topics. Crypto7 your own thread is now here: T-Rex 4.6 and official Irdeto card | ||
| | #43 | ||
![]() | Hi marc1_007, it would help if you told us which channels are freezing, is it all of them or just a few encrypted channels? Which satellite channels are you trying to view? MCT porn channels are not available on the Dragon Cam, at the moment, as far as I'm aware, so are you using a subscription card? | ||
| | #44 | ||
My System: hotbird satellite with digiquest 8000sci receiver with a t-rex cam and access card | he suggested that i change the cam slots he gave me a whole list of encrypted channels that are supposed to work with the cam and i have tried quite a few of them maybe 10 or more and they do work fine but only for about 30 secs and then the picture freezes up i have a list of all the channels here i can paste them on but the ones i have tried so far are all the multivision channels,he actually said all the mct channels worked but they obviously don't, the channels on the ZIK,manga and action frequency, the espn channels, the eurosport channels,my satellite point towards the hotbird satellites so i have the best frequency on hotbird and he sent me some for astra but even when i connected my sky cables to install astra channels i did not get any of the ones he illustrated such as the premiere channels, taquilla and the canal channels here is the actual list he posted that got me interested in the first place it is a long list but here goes. Channels currently open are as follows : Now including MCT Channels on Hotbird Hotbird - TV CHANNELS Frequency Pol. SR FEC Provider_Name Encryption Caid Provid Keyid_in_use 10.722 H 29900 3/4 British Telecom Cryptoworks 0D03 0000A0 00 Channel Name V-PID A-PID SID 10.722 H (Jetix Central & Eastern Europe) 1005 1205 4605 E! Europe 1007 1207 4610 10.758 V 27500 3/4 TPS TpsCrypt3 0500 007C00 08 (with daily Aes Keys) C CINEMA FRISSON 120 130 1201 C CINEMA PREMIER 220 230 1202 C CINEMA CLASSIC 320 330 1203 TPS Star 420 430 1204 C CINEMA STAR 520 530 1205 C CINEMA CULTE 620 630 1206 C CINEMA EMOTION 720 730 1207 C CINEMA FAMIZ 820 830 1208 C CINEMA PREMIER 16/9 920 930 1209 10.796 V 27500 3/4 TPS TpsCrypt3 0500 007C00 08 (with daily Aes Keys) Infosport 120 130 1401 EURÊKA ! 220 230 1402 Série Club 320 330 1403 Fun TV 420 430 1404 Téva 520 530 1405 Télétoon 620 630 1406 Paris Premiere 720 730 1407 Piwi 820 830 1408 TPS Foot 920 930 1409 M6 Music Hits 1020 1030 1410 SIC 1220 1230 1412 10.834 V 27500 3/4 TPS TpsCrypt3 0500 007C00 08 (with daily Aes Keys) FRANCE 2 320 330 1103 EUROSPORT 2 420 430 1104 FRANCE 3 520 530 1105 OL TV 920 930 1109 FRANCE 2 320 330 1120 FRANCE 3 520 530 1121 10.873 V 27500 3/4 TPS TpsCrypt3 0500 007C00 08 (with daily Aes Keys) M6 Music Rock 120 130 1501 Equidia 320 330 1503 ESPN CLASSIC 420 430 1504 FRANCE 4 520 530 1505 USHUAIA TV 620 630 1506 TV Breizh 720 730 1507 FRANCE 5 820 830 1508 France Ô 920 930 1509 La Chaîne Parlamentaire 1020 1030 1510 Equidia Alpha 320 330 1513 M6 Music Black 220 230 1515 Equidia Outlist 320 330 1520 FRANCE 5 820 830 1521 La Chaîne Parlamentaire 1020 1030 1522 FRANCE 4 520 530 1523 10.911 V 27500 3/4 TPS TpsCrypt3 0500 007C00 08 (with daily Aes Keys) M6 120 130 1601 Eurosport 220 230 1602 Histoire 320 330 1603 TF1 420 430 1604 TFOU 520 530 1605 Odyssée 620 630 1606 TF6 720 730 1607 LCI 820 830 1608 Télétoon+1 920 930 1609 Privatespice 1020 1030 1610 (daily from 00:00 to 05:00) Planéte Thalassa 1120 1130 1611 M6 120 130 1620 TF1 420 430 1621 10.949 V 27500 3/4 Cyfra+ Mediaguard2 0100 000065 0D CN/TCM CEE Comb 7801 7811 7457 Disney Channel 7401 7411 7466 Cartoon Network 7501 7511 7467 Turner Classic 7601 7611 7468 10.971 H 27500 3/4 TPS Viaccess 2.3 0500 007C00 08 Baby TV 263 519 7 10.992 V 27500 2/3 Rai International Biss 2600 002136 Rai Asia 200 650 8502 10.992 V 27500 2/3 Rai International Biss 2600 002135 Rai Africa 100 36 8501 11.034 V 27500 3/4 TPS TpsCrypt3 0500 007C00 08 (with daily Aes Keys) W9 120 130 1701 BOOMERANG 320 330 1703 TELE MELODY 520 530 1705 BERBERE TV 1120 1130 1711 PINK TV 1220 1230 1712 W9 120 130 1720 11.075 V 27500 3/4 TPS Viaccess 2.3 0500 007C00 08 Game One 162 88 3 VH1 166 104 7 MTV France 168 112 9 11.116 V 27500 3/4 TPS Viaccess 2.3 0500 007C00 08 BBC Prime 6001 6011 14601 11.137 H 27500 3/4 TPS Viaccess 2.3 0500 007C00 08 Motors TV 521 641 7301 11.240 V 27500 3/4 Cyfra+ Mediaguard2 0100 000065 0C ESP2 Int'l 2825 2823 13801 EUSP2 PL 2825 2818 13802 ESP2 Rus 2825 2828 13813 ESP2 Greek 2825 2823 13805 ESP2 Romanian 2825 2850 13821 ESP Int'l 2577 2562 13831 ESP Romanian 2577 2569 13832 ESP Dutch 2577 2564 13833 ESP Polish 2577 2562 13834 ESP Russian 2577 2566 13835 ESP Portuguese 2577 2568 13836 ESP Hungarian 2577 2584 13837 ESP Czech 2577 2582 13839 ESP Greek 2577 2562 13840 ESP Cyprus 2577 2562 13841 ESP Bulgarian 2577 2585 13842 ESP2 Turk 2825 2823 13843 ESP Serbia 2577 2842 13844 ESP Turk 2577 2838 13845 ESP2 German 2825 2826 13846 11.278 V 27500 3/4 TPS Viaccess 2.3 0500 007C00 08 CNBC 171 120 13012 11.296 H 27500 3/4 Sat2000 Biss 2600 0020D2 S2K 330 331 8402 11.393 V 27500 3/4 Cyfra+ Mediaguard2 0100 000065 0C TVN 512 650 4311 TVN 24 513 660 4312 TVN Siedem 514 670 4313 TVN METEO 519 720 4318 TVN TURBO 520 730 4319 TVN Style 521 740 4320 11.411 H 27500 3/4 Telekom Serbia Biss 2600 00377D FOX TV 1701 1702 14205 11.526 H 27500 3/4 Srg Ssr Swiss Viaccess 2.3 0500 009400 0E TSR1 27500 3/4 161 84 14002 TSR2 27500 3/4 164 96 14008 TSI1 27500 3/4 162 88 14003 TSI2 27500 3/4 166 100 14009 11.623 V 27500 3/4 TPS Viaccess 2.3 0500 007C00 08 KBS WORLD 229 249 10709 11.662 V 27500 3/4 TPS TpsCrypt3 0500 007C00 08 (with daily Aes Keys) MULTIVISION 1 120 130 1301 MULTIVISION 2 220 230 1302 MULTIVISION 3 320 330 1303 MULTIVISION 4 420 430 1304 MULTIVISION 5 520 530 1305 MULTIVISION 6 620 630 1306 MULTIVISION 7 720 730 1307 OM TV 820 830 1308 COMEDIE! 1020 1030 1310 SPORT+ 1120 1130 1311 11.681 H 27500 3/4 TPS TpsCrypt2 0500 007C00 0B (with daily Aes Keys) AB 1 160 80 201 AB MOTEURS 161 84 202 CHASSE & PECHE 163 92 204 ZIK / XXL 164 96 205 XXL 164 96 213 'ZIK 164 96 214 XXL PL 164 96 215 ESCALES 166 104 207 ACTION 169 116 210 MANGAS 170 120 211 RTL9 172 128 200 12.188 V 27500 3/4 Polsat Nagravision2 1801 007101 86 Zone Romantica 1541 1542 7301 AXN Crime 1539 1540 7302 AXN Sci-fi 1537 1538 7303 Extreme Sports 321 322 7305 Discovery 341 342 7315 Animal Planet 344 345 7316 AXN 353 356 7318 ESPN 545 546 7340 KINO POLSKA 2307 2305 7342 Jetix 337 338 7349 Cinemax2 548 549 7370 TVP1 801 802 7371 Test_P 806 807 7372 TVP2 817 818 7373 FoxLife 272 273 7375 12.245 H 27500 3/4 TPS Viaccess 2.3 0500 007C00 08 MEZZO 125 135 105 I>TELE 222 223 100 I>TELE 222 223 192 12.285 H 27500 3/4 Polsat Nagravision2 1801 007101 86 E! 257 258 10501 Boomerang 513 514 10502 Zone Europa 353 354 10507 Zone Club 369 370 10508 Dla Abonentow 532 533 10511 Zone Reality 535 536 10514 Playboy 868 869 10516 Jetix Play 401 402 10517 TV 1000 1281 1282 10518 Travel 566 567 10520 Science 544 545 10521 Civilisation 561 562 10522 12.303 V 27500 3/4 Tv Slovenia Viaccess 2.3 0500 00B000 08 SLO-TV1 200 201 3201 SLO-TV2 3/4 203 204 3202 12.322 H 27500 3/4 Cyfra+ Mediaguard2 0100 000065 0C TRACE TV 36 37 14801 12.399 H 27500 3/4 Srg Ssr Swiss Viaccess 2.3 0500 009400 0E SF 1 160 80 901 SF zwei 163 92 907 TEST 1 170 120 991 TEST 2 171 122 992 TEST 3 172 124 993 TEST 4 173 126 998 TEST 5 174 128 999 12.577 H 27500 3/4 TPS Viaccess 2.3 0500 007C00 08 Sailing Channel 1210 1310 8110 12.597 V 27500 3/4 TPS Viaccess 2.3 0500 007C00 08 CNNI 168 112 8209 12.692 H 27500 3/4 TPS TpsCrypt2 0500 007C00 0B (with daily Aes Keys) TMC 164 96 505 CINE POLAR 165 100 506 CINE FX 166 104 507 TMC 164 96 540 Hotbird - RADIO CHANNELS Frequency Pol. SR FEC Provider_Name Encryption Caid Provid Keyid_in_use 10.719 V 27500 3/4 TPS Viaccess 2.3 0500 007C00 08 Channel Name A-PID SID Music Choice 3 601 4481 (the first only of 6 audio channels) Music Choice 4 607 4482 (the first only of 6 audio channels) 10.873 V 27500 3/4 TpsCrypt3 0500 007C00 08 (with daily Aes Keys) Fun Radio 3139 3109 RTL 2 3140 3110 RMC 3236 3206 10.911 V 27500 3/4 TpsCrypt3 0500 007C00 08 (with daily Aes Keys) BFM 3134 3104 Contact FM 3231 3201 Skyrock 3239 3209 Sport FM 3332 3302 11.283 V 27500 3/4 TPS Viaccess 2.3 0500 007C00 08 Music Choice 5 613 13081 (the first only of 6 audio channels) Music Choice 6 620 13082 (the first only of 5 audio channels) Music Choice 7 625 13083 (the first only of 6 audio channels) 11.487 H 27500 3/4 TPS Viaccess 2.3 0500 007C00 08 Music Choice 1 631 5181 (the first only of 5 audio channels) Music Choice 2 637 5182 (the first only of 6 audio channels) 12.285 H 27500 3/4 Polsat Nagravision2 1801 007101 86 Test Radio 2 4369 10519 RMF FM 774 10523 RMF FM 774 10538 Astra1 - TV CHANNELS Frequency Pol. SR FEC Provider_Name Encryption Caid Provid Keyid_in_use 10.788 V 22000 5/6 Digital+ Nagravision2 1801 004101 96 Channel Name V-PID A-PID SID TAQUILLA XY 160 80 30357 TAQUILLA 4 167 108 30353 TAQUILLA 1 168 112 30350 TAQUILLA 2 170 120 30351 TAQUILLA 3 171 124 30352 CARTOON NET. 161 84 30358 BOOMERANG 163 92 30361 LA SEXTA 165 100 30356 10.818 V 22000 5/6 Digital+ Nagravision2 1801 004101 96 CANAL+ ACCION … 30 160 80 29950 CANAL + COMEDIA … 30 161 84 29951 FOX 165 100 29955 AXN 166 104 29956 DCINE ESPAÑOL 167 108 29952 CANAL COCINA 168 112 29953 SCI FI 171 124 29958 TVE 1 170 120 29957 ECUAVISA INTERNATIONAL 173 132 29961 CARACOL INTERNATIONAL 164 96 29962 10.877 V 22000 5/6 Digital+ Nagravision2 1801 004101 96 C+ FUTBOL 161 84 30620 40 LATINO 165 100 30600 GOLF+ 166 104 30601 CANAL+...30 167 108 30602 FOX NEWS 168 112 30611 NAT GEOGRAPHIC 170 120 30605 C+ DEPORTES 172 128 30621 PLAYBOY TV 173 132 30603 C+ DEPORTES 172 128 30607 C+ FUTBOL 161 84 30606 40 LATINO 165 100 30604 10.979 V 22000 5/6 Digital+ Nagravision2 1801 004101 96 CLÁSICO 161 84 30651 24 HORAS 162 88 30652 TNT 163 92 30653 TELENOVELAS 165 100 30656 HOLLYWOOD 166 104 30657 CANAL HISTORIA 167 108 30658 EUROSPORT 168 112 30680 CUATRO 173 132 30662 CLAN TVE 160 80 30654 CUATRO 173 132 30663 24 HORAS 162 88 30655 TELENOVELAS 165 100 30659 11.038 V 22000 5/6 Digital+ Nagravision2 1801 004101 96 CANAL+ 160 80 30400 DOCU TVE 161 84 30401 DISNEY CHANNEL 163 92 30403 SPORTMANÍA 164 96 30404 40 TV 165 100 30405 DISCOVERY 166 104 30406 CANAL+ 2 168 112 30410 TELEDEPORTE 170 120 30412 11.097 V 22000 5/6 Digital+ Nagravision2 1801 004101 96 TAQUILLA 5 160 80 30053 TAQUILLA XX 161 84 30058 TAQUILLA X 163 92 30056 TAQUILLA XX 164 96 30057 TAQUILLA 7 168 112 30055 BARÇA TV 169 116 30052 TAQUILLA 6 171 124 30054 C+ EVENTOS 162 88 30062 C+ EVENTOS 162 88 30059 TAQUILLA 8 170 120 30063 11.156 V 22000 5/6 Digital+ Nagravision2 1801 004101 96 LA 2 162 88 30509 CALLE 13 163 92 30510 PEOPLE+ARTS 165 100 30504 VIAJAR 166 104 30505 PARAMOUNT COM 167 108 30506 BLOOMBERG 161 84 30511 CAZA Y PESCA 169 116 30507 COSMOPOLITAN 170 120 30512 MÉTEO 164 96 30514 MÉTEO 164 96 30508 11.318 V 22000 5/6 Digital+ Nagravision2 1801 004101 96 DOCUMANÍA 160 80 29800 JETIX 161 84 29801 C+ ACCION 162 88 29810 C+ COMEDIA 163 92 29811 DISNEY CH. +1 164 96 29802 PLAYHOUSE 165 100 29803 TOON DISNEY 169 116 29807 C+ DCINE 170 120 29812 INTERECONOMÍA 171 124 29813 C+ DCINE 170 120 29806 C+ COMEDIA 163 92 29805 C+ ACCION 162 88 29804 11.685 V 22000 5/6 Digital+ Nagravision2 1801 004101 96 TCM CLÁSICO 165 100 30220 FDF 166 104 30221 CNN+ 169 116 30210 CANAL ESTRELLAS 168 112 30206 CNN+ 169 116 30207 11.720 H 27500 5/6 Premiere Nagravision2 1801 000501 86 PREMIERE SPORT PORTAL 255 256 17 PREMIERE FILMFEST 1279 1280 20 PREMIERE FILMCLASSICS 1023 1024 41 PREMIERE NOSTALGIE 1535 1536 516 PREMIERE DIREKT 1 767 768 220 PREMIERE SPORT 2 511 512 222 PREMIERE DIREKT 4 +0.5 2559 2560 242 PREMIERE DIREKT 3 2815 2816 243 PREMIERE DIREKT 2 3071 3072 244 11.739 V 27500 5/6 Digital+ Nagravision2 1801 004102 96 MTV ESP 3011 3012 28651 VH1 3061 3062 28656 NICK ESP 3101 3102 28660 11.759 H 27500 1/2 Premiere Nagravision2 1801 000501 86 JUNIOR 255 256 19 DISCOVERY CHANNEL 1023 1024 14 JETIX 1279 1280 28 DISCOVERY GESCHICHTE 1535 1536 13 BEATE-UHSE.TV 1791 1792 21 (daily from 20:00 to 06:00) DISNEY CHANNEL 2559 2560 34 ANIMAL PLANET 2815 2816 12 FOCUS GESUNDHEIT 3071 3072 15 PREMIERE DIREKT 3 3327 3328 226 PREMIERE DIREKT 2 +0.5 3583 3584 227 PREMIERE SPORT 1 2047 2048 221 11.778 V 27500 3/4 Turner Cryptoworks 0D03 00005C 00 Cartoon Network France 161 84 28521 TCM France 169 64 28525 TCM Espana 164 96 28526 Boom/TCM 167 113 28520 BFT 166 102 28527 11.798 H 27500 3/4 Premiere Nagravision2 1801 000501 86 PREMIERE 1 511 512 10 PREMIERE 4 767 768 9 PREMIERE 2 1791 1792 11 PREMIERE 3 2303 2304 43 PREMIERE SERIE 2559 2560 16 PREMIERE KRIMI 2815 2816 23 PREMIERE DIREKT 1 +0.5 3071 3072 224 PREMIERE DIREKT 5 3327 3328 225 11.817 V 27500 3/4 Digital+ Nagravision2 1801 004201 96 I>TELE 169 116 8010 I>TELE 169 116 8021 MEZZO 166 104 8007 MEZZO. 166 104 8012 11.915 H 27500 9/10 Premiere Nagravision2 1801 000501 86 Premiere HD Film 767 771 129 Discovery HD 1279 1283 131 12.032 H 27500 3/4 Premiere Nagravision2 1801 000501 86 13 TH STREET 511 512 42 EROTIK - AB 18! 1279 1280 513 BIG BROTHER 3839 3840 27 SCI FI 791 1792 36 MGM 2047 2048 515 PREMIERE DIREKT 5 +0.5 3071 3072 208 PREMIERE DIREKT 4 3327 3328 209 12.071 H 27500 3/4 Premiere Nagravision2 1801 000501 86 CLASSICA 767 768 24 HIT24 1023 1024 168 HEIMATKANAL 1279 1280 22 arena home 2559 2560 50 GOLDSTAR TV 3839 3840 518 PREMIERE START 3071 3072 8 PREMIERE EROTIK 2 3327 3328 780 PREMIERE DIREKT 1 +1 511 512 212 BLUE MOVIE 2047 2048 665 BLUE MOVIE EXTRA 2303 2304 666 BLUE MOVIE GAY 2815 2816 671 PREMIERE EROTIK 1 1535 1536 778 12.149 H 27500 3/4 Premiere Nagravision2 1801 000501 86 BD1 (Champions TV Galopp) 1791 1792 771 BD4 (Champions TV Trab) 2047 2048 773 PREMIERE Austria 2559 2560 53 12.692 H 22000 5/6 Orf Betacrypt 1762 000000 05 ORF1 160 161 13001 ORF2 500 501 13002 ATV+ 506 507 13012 ORF2 W 500 501 13003 ORF2 N 500 501 13004 ORF2 B 500 501 13005 ORF2 O 500 501 13006 ORF2 S 500 501 13007 ORF2 T 500 501 13008 ORF2 V 500 501 13009 ORF2 St 500 501 13010 ORF2 K 500 501 13011 Astra1 - RADIO CHANNELS Frequency Pol. SR FEC Provider_Name Encryption Caid Provid Keyid_in_use 12.032 H 27500 3/4 Premiere Nagravision2 1801 000501 96 Channel Name A-PID SID P-60ER 816 145 P-DINNER PARTY 640 146 P-KLASSIK 656 147 P-JAZZ 624 148 P-COUNTRY 784 149 P-UK HITS 336 150 P-DEUTSCHE CHARTS 400 151 P-HARD ROCK 384 152 P-SOUL CLASSICS 800 153 P-ROCK N ROLL 544 154 P-CLASSIC ROCK 352 155 P-LOVE SONGS 608 156 P-REGGAE 832 157 P-ALTERNATIVE ROCK 880 158 P-R&B/HIP HOP 848 159 P-SCHLAGER 528 162 P-ROCK HYMNEN 368 163 P-90ER 592 164 P-DANCE 864 165 P-70ER 560 166 P-80ER 576 167 | ||
| | #45 | ||
![]() | Without going through your entire list I can tell you thet the Dragon Cam can not open any TPS channels on Hotbird, these channels change keys every few minutes so may be open for 30 seconds between key changes. That list was probably from a couple of years ago, and things change rapidly in this hobby. You can open: Astra 1 19.2E The Premiere package, the channels you have listed. The Digital + channels you have listed. Hotbird 13E SRG Swiss package, about 6 channels. Hispasat 30 W TV Cabo package Digital + package, same channels as on Astra 1 but different frequencies A few other channels from various satellites but these are the main package of channels. To open Premiere you require Predator 359 loaded onto your cam, and to open any of them require you to manually update the keys. You can do this by going into the cams menu, using your receivers remote control, and selecting Debug, and OhlAladin. Here you will find Digital +, TV Cabo, and Premiere. Select the one that you want to update, and select the key that needs updating key 00 or key 01, and enter the new decimal key, a series of 3 numbers. Thes will be in 16 sets of 3 numbers, which are split in the Dragon Cam. For example if you're updating key 00. Click on key 00-0 and enter the first 8 sets of 3 numbers. Then click on 00-1 and enter the next 8 sets of 3 numbers. It's that easy. D+ and TV Cabo require the keys updating regularly so you will soon get used to it. | ||
| | #46 | ||
My System: hotbird satellite with digiquest 8000sci receiver with a t-rex cam and access card | thank you so far mickha i am certainly learning more as i plod along the version of the upgrade i have is the predator EMPB if that makes any sense i viewed it on my common interface screen i have followed your instructions on debugging and using ohlaladin and the options i have are D+, Cabo, Pol, Prem, Globo, RSC, Kabel and another D+. The problem i now have since the hotbird channels are no good to me, is to get the astra1 channels because as my satellite seem to favour hotbird because that is where i get the best reception on my receiver i can only install a select few astra1 channels due to bad reception and the premiere package, canal package, and taquilla package are definitely not one of these i can receive when i try tuning them myself, the same goes for the hispasat channels as well, so might it be a case where i have to change the direction of my satellite dish basically starting from scratch to be able to get these because i have a sky dish as well and i connected the cable to my receiver to see if i could tune the astra1 channels and all i can get are the main sky channels so thats no good either | ||
| | #47 | ||
My System: hotbird satellite with digiquest 8000sci receiver with a t-rex cam and access card | could it also be a case that my receiver is old i bought it 3 years ago and on the antenna set up i have hispasat 1ABC instead of hispasat 30W and astra 1,2 and 3 instead of astra1 19.2E or is this just a case of changing longitude and latitude or do i have to reposition my dish . Please bear with me as i am totally new to this and have never taken an interest in it until now | ||
| | #48 | ||
![]() | EMPB is a member on other satellite boards that modifies Predator files, as you progress, in this hobby, you will be able to do that yourself. New S*y dishes, mini dishes, point at 28,2E, so these are the only channels you can get off that satellite, which include BBC, ITV and other British channels. I assume that you currently have a fixed dish, not motorised, so you will have to move the dish 6 degrees East, and alter the elevation slightly, to get Astra 1. Another option is to get a new, patchable, receiver, you can pick up a Technomate for £60 - £90, depending on the model, which when patched can currently open TPS, D+, Premiere and TV Cabo, or you can get a Cas 3+ programmer, and Diablo light Cam, for around £90, which will also open TPS and the other packages. You might want to consider fitting a motor to your dish, as this will provide you with more options in the future. | ||
| The Following User Says Thank You to Mickha For This Useful Post: | EMPB (08-12-2007) |
| | #49 | ||
My System: hotbird satellite with digiquest 8000sci receiver with a t-rex cam and access card | my dish points at 13.0E but your right the best option for now is to probably get a new patchable receiver | ||
| | #50 | ||
| Member Join Date: 25-07-2006 Location: north east
My System: satellite on astra 19.2 fixed dish,technosat d digit mf4-s reciever technomate 5400 usb sat on 1w diablo,trex and various cards | just read an interesting article in a german sat forum that said, the trex cam and support for this cam are heading to the bottom floor due to lack of support, if so does it make sense to invest in a diablo light and has this cam good support. | ||
| cam, trex |
