T-Rex cam
Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex.
Old 08-12-2007   #76
Hi, guys
This may not be the place to ask, but I have searched through the forum and couldn't find anything about Eurosport and Eurosport2. Few days ago I was able to open them on Hot Bird 13° after last Predasaur223 download.
Would you know what the encryption is and where to put the keys if available?
Thanks a lot for sharing your knowledge
Simel
simel is offline   Reply With Quote
Old 08-12-2007   #77
As it was on 13E I assume it would be part of the Polsat package and they should still be available if you have the latest keys.
You can enter these keys manually using the debug option in your cams menu.
Go to OhlAladin 7101 Polsat, select the key thet requires updating and enter the decimal keys.
Mickha is offline   Reply With Quote
The Following User Says Thank You to Mickha For This Useful Post:
simel (09-12-2007)
Old 08-12-2007   #78
Polsat
Yes Eurosport 13E 11.240V open's with Polsat's Nagra2 Keys. They changed to a new IDEEA 86 / Key 00 yesterday
"It's All Good"
EMPB is offline   Reply With Quote
The Following User Says Thank You to EMPB For This Useful Post:
simel (09-12-2007)
Old 10-12-2007   #79
smyfffy's Avatar
My System: new
hi ...HELP iv just got off Ebay a trex 4.6 with Predasaur222 on the guy said it should be alright with out a loader card just key in daily codes anyway im using in portugal and got one dish hispa 30.w and one with hot bird and astra 1. prob is that i cant find were i get the daily dec codes ...and do i need a loader card ...get loads of scrambled channels help plsssssssssssss
smyfffy is offline   Reply With Quote
Old 10-12-2007   #80
You just need to manually update the keys for Premiere, 19E, Polsat, 13E, and SRG 13E.
For TPS just leave your receiver tuned to Sci Fi, or other channel using the same frequency, for a few minutes and it should open, then you can browse the other channels in that package,
To input the keys go into the cam menu, Debug, OhlAladin and the relevant provider.
If you have a look through the forum you will find the links section, with links to lots of useful sites.
Also look for posts with links to sites like sendspace as other members will quickly post the keys after a change.
If you could get 1W Digi TV is also available, which is quite a good package.
Old 05-01-2008   #81
My System: Radix 5000 Panasonic TU-DSB31 Triasat SR 4003 (analogue receiver), 3 dishes, each 90 cm, Infinity USB Unlimited T-Rex Loadercard T-Rex Supermodule
Directions please
Hi
Have just received a T-Rex Supermodule + Loadercard.
Could somebody please direct me to a site/thread where I can read about what receiver to get? I am not looking for something really fancy... just something that can deal with the T-Rex and I might find cheaply on e-bay...
Cheers
Mac4555
Mac4555 is offline   Reply With Quote
Old 24-04-2008   #82
Witha Nokia 9800 S- via 2.5 embedded
I would heartily welcome guidance in the selection of a proper
Multicam with temporary capabilities.
Will the T REX Supermodule 4.6 be perfectly compatible with Nokia 9800 S.
Besides the T Rex supermodule , what other accessories required to
complement the functioning of the module.
I understand that T rex is different from the Dragon equivalent, in what
ways. Please explain in a basic language.
MANY thanks for showering me with these ibnformation which will
me to order the selected module with proper specifications.
Best Wishes,
kadnor
Originally Posted by Mickha View Post
Hi stuzeeuk,
the Cas 3 is a duolabs product, and requires the latest drivers to program the Dragon Cam, you can download these from duolabs.com, click on download and Cas 3 download.
I will post some instructions when you get your programmer, as I need to know if you are planning to use a loader card or just the Cas 3.
You can still update the available keys, including D+, via the debug option in the Cam menu.
D+ is located in OhlAladin.
Best wishes
Mickha
kadnor is offline   Reply With Quote
Old 24-04-2008   #83
The T-Rex v1 is exactly the same as the Dragon Cam v4.1, merely a change of name.
The T-Rex 4.6 supermodul was the last cam produced but again this is basically the same as the Dragon Cam only it has a secure are for non public hacks.
Support for both these cams seems to have ceased so this feature doesn't seem very important.
The latest Cam is the Jolly Cam, or the Diablo v2.3, which is supposed to have more memory.
To program a Dragon/T-Rex Cam, any version, requires either a loader card and card programmer, capable of programming a Fun Card 7 or a PIC F84A loader card, or a Cas 3 and dummy card.
To program a Diablo cam requires a Cas 2 or Cas 3 programmer, but the older Cas 2 has been known to have problems.
To find out if any of these cams works with your receiver, Nokia 9800 S, you need to ask fellow owners who have tried these cams.
Old 24-04-2008   #84
My System: t-rex super module
hello cava biem a forum
badia is offline   Reply With Quote
Old 15-09-2009   #85
Real name: Lawrence
My System: I am From malta and i am interested in setting sats and experimenting around!!!
i have a t rex twin modulerev 1.0 how can i updated and what i can watch with it. please help. my reciever is echostar dsb2300 2ci can i update this reciever some how pls.
thanks in advance regards
Lawrence
kalaw28 is offline   Reply With Quote
Old 15-09-2009   #86
A T-Rex V 1.0 is the same as a Dragon 4 cam so you just load the latest predator file onto it.
What card programmer and loader card have you got? Or are you using a Cas 3 programmer?
If you just put predator370 no spaces, into a search engine you will soon find an updated file.
Unfortunately there's not a lot available anymore mainly just the Digi TV package on 1 West.
simel (19-09-2009)
cam, trex
