Card\cam with usb interface ?
Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex.
Old 13-11-2006   #1
Darren Rainer's Avatar
My System: Humax receiver Jaeger 128 H-H mount Channel Master 1.2M dish 0.3nf LNB
Hi, is there a cam/card I can buy a usb interface so that I can download keys and let my pc decode or does it have to be done by a programmed card ?
Ideally I would like to use my existing receiver which has viaccess and conex embedded cams and plug in a card which has a wired connection to my laptop. I would then run some software and let the pc do the decoding. Is this possible ?
Darren Rainer is offline   Reply With Quote
cardcam, interface, usb
