Will T-REX/DRAGON/Diablo open ABSat?Satellite TV support fourm for X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex. | |
| Regular Member Join Date: 05-08-2004 Location: South Wales
My System: Echostar 808 CI Via Jokercam-Retired!,T-REX, Rusty Old 80cm mesh dish on fence pole! |
Hi All, Are the Absat channels open on HB13 or astra 19.2 with any of the above ? And if so do they need any cards inserted with hex files on them like my Joker used to use i.e Funcards. Thinking of Upgrading my cam to get ABMoteurs. I have an Elvis Programmer with TJ multiprog software if thats any use to program or update the cams via funcard, Or would I be better off changing my receiver to a Dreambox? Any advice appreciated! Thanks in advance. | ||
My System: Echostar 808 CI Via Jokercam-Retired!,T-REX, Rusty Old 80cm mesh dish on fence pole! | Thanks Mickha, Can my Elvis programmer upgrade the predator firmware? If so, would that be via a Funcard or reprogramming the "T-Rex/Dragon Loader Card" that is advertised with the CAM? | ||
| Super Moderator Join Date: 10-12-2004
![]() | The Dragon/T-rex cams can be updated using either a Fun Card 7 or a PIC F84A loader card, by loading the latest Predator version on the card and then into the cam, following the guide. The only other way to update a Dragon/T-Rex cam is with a Cas 3. | ||
| | #5 | ||
My System: Echostar 808 CI Via Jokercam-Retired!,T-REX, Rusty Old 80cm mesh dish on fence pole! | Thanks again Mickha, Used my trusted Elvis and a Funcard 7 to program CAM. Recevied my t-rex last week, programmed with Predasaur 2.13 and ran security update but it didnt work. I then loaded Predator 3.56 and hey presto Pre*ier package opened on 19E ! Now I can watch my NASCAR and in english! Any reason why 2.13 would not work and 3.56 did? I did notice that the echonav channel list menu seemed to be quite slow and would not automatically show all channels when selected at first but seems ok now. | ||
| | #6 | ||
![]() | Predasaur 2.13 is opening Premiere, for me, there hasn't been a change since 2.12, and D+ AU is also working. Did you try the original Predasaur 2.13 and not a modified version, as some Echostar receivers, mine included, have problems with the extra CAID's added. There is a lot of choice currently on 19E, I just hope we get to keep Premiere for the rest of the Champions League football. | ||
| | #7 | ||
My System: Echostar 808 CI Via Jokercam-Retired!,T-REX, Rusty Old 80cm mesh dish on fence pole! | Looks like it was a modified 2.13D+Au file from sat-key website. I will remember to use an original file for next time. | ||
| absat, open, trex or dragon or diablo |
