1.5m Offset Vs 1.8m Prime Focus ?
T
tux233
Likes
Hi
Need to upgrade from 1m due to dropouts and weak signal on some sats. I have been reading most if not all posts on this forum regarding dish sizes etc. and was inclined on a Gibertini 1.5m offset dish. I prefer offset as these make it possible to mount closer to a wall. If I go for prime focus the mounting location has to be changed. Bit of a hassle, but possible....
Now... Is this Gibertini dish any good?
Will I get a substancial signal gain from 1.8m prime focus? I'm thinking 1.8m prime focus signal minus LNB shadow = 1.5m Offset. Is this correct?
Also been looking for a dish comparison site, but none found. So I seek help from this forums experienced members.
Much obliged.
Cheers
Topper
Topper
Amo Amas Amant Admin
Likes
3,368
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#2
I am sure there are people willing to impart the required knowledge and information but unfortunately you do not say where you are located and what channels are dropping out and from which satellite so all in all it is therefore difficult for anyone to comment without a comparison benchmark.
T
tux233
Likes
My location is :
Madeira Island (32.633N/-16.850W)
I can give 7W as an example. I receive that sat at 60 to 65% after sundown but rest of the time at 50%.
Topper
Topper
Likes
3,368
#4
tux233 I can certainly understand why when looking at the footprint here Not really a dish expert and therefore unable to advise you personally but being off the west coast of N Africa you are nearer to the footprint than the UK is. Again you mention no channels but we wouldn't have a comparison from here anyhow as we have difficulties with Nilesat (not surprising really) as it covers N Africa and Middle East. If you have done all you possibly can regarding fine tuning then yes a bigger dish will pull in more signal but will require more accurate alignment as well!
T
tux233
Likes
Thank you toppervte33h....
I do realize that due to my location, I need a bigger dish. Have been looking at footprints for all the concerned channels/sats/transponders/polarization for some time now.
My question is about what dish upto 1.8m has the best gain. Ideally, for my location, would be 2.4m or even 3m.
So would the 1.5m offset perform as well or better than the 1.8m P.Focus?
Cheers
Lancelot
Lancelot
Retired Mod
Likes
SS1.
36v H to H 62E - 61.5W
South central
#6
Why not compromise and get a 1.8 mtr offset ?. It would need to be a good quality one though.
L.
T
tux233
Likes
L.
Any recomendations ?
Lancelot
Lancelot
Retired Mod
Likes
SS1.
South central
#8
The Channelmaster / Andrews 1.8 offset is good but you pay for what you get.
L.:)
T
tux233
Likes
Didn't know Channel Master had that size offset dishes....nothing on their website.
I have e-mailed them for a EU dealer, but in the meantime could anyone please point me to a site with info on these dishes.
T
tux233
Likes
Hi
Still looking for the ultimate offset dish :D . Found this 1.80 offset dish with the following specs:
CARACTERISTICAS:
  • Dimensiones totales: 1890 x 1720 mm
  • Diámetro mayor: 1880 mm
  • Diámetro menor: 1700 mm
  • Material del Disco: Aluminio
  • Tratamiento de la superficie: Epoxi-poliester
  • Diámetro máx. de mástil: 100 mm
  • Elevación: 5 º a 78 º
  • Diámetro de la abrazadera del LNB: 40 mm
  • Resistencia al viento: 200 Km/h
  • Peso: 28.10 Kg
  • Eficiencia (%): 80 %
  • Ganancia: (dB a 12.5 Ghz): 46 dB <----- Looks Good.
The site does not mention the manufacturer. Can anyone identify this dish from the pic. If so, is it as good as advertised?
Thank you all for the replies.
S
steffo78
Likes
28E 19E on 120cm Gibertini homemade sidemount with Gibertini feedhorn, Inverto C120. 5E 1W on 85cm triax. Digiality VC-CI 204 and Triax dvb-65s receivers. Matrix-cam not working. Swedish Canaldigital &quot;local&quot;, Norwegian Viasat.
Sweden/Norway,Telemark
#13
The dish is possibly a Mabo from Poland, but the gain is 1 dB too much and they do not specify their effiency.
Anyhow, this dish has an effiency of 57% when I try it at www.satellite-calculations.com so it might not be your best buy.
Also the measurement you use for comparing is 170cm on this dish.
L
Likvid
Likes
5
Stockholm, Sweden
#14
I heard the Polish dishes are really crap, even worse than the Chinese manufacturers.....
There are good quality European and American manufacturers out there so i would suggest one of them instead.
D
deepbluesky
Likes
76
Terratec T-Stick+ (DAB+)
Stuttgart (48.79N/9.19E)
#15
I only know Mabo as a traditional polish manufacturer and as some friends of mine told me they are quite confident with the 1.85m Offset having them some years in Greece at sea climate conditions without any problems. Surely US made ones are better but i wouldn't call them crappy.
Zorba
Zorba
Likes
7
3m(28.2E),1.5m(19.2E.13E,10E),1m (4W ,7W)1m (?).diseqc 10,sky plus,VU+,telergy iptv.
Satlook nit colour + Horizon hdsm.
Limassol, Sunny Cyprus
#16
The Supral from Russia is very good.
T
tux233
Likes
Just wanted to thank all for the help. I have ordered a channel master 1.80m offset :D
Cheers
Lancelot
Lancelot
Retired Mod
Likes
SS1.
South central
#19
Good choice, I'm sure you won't be disappointed :)
L.
