- Oct 21, 2006
- See signature
- North Somerset
OK, so it's not much of a project; simply an installation of a 1m Channel Master dish (formerly Tooway!). This will be going on the side of the house, with view of full arc - hoping from 70.5e all the way to 60w and beyond (not that there's much there). This will be going on the H-to-H motor that's doing the rounds on eBay at the moment and on a nice 3" pole (ooeer!)
But anyway, need some advice. I have several mounting options:
1) T&K bracket and pole - nice and simple but dog ugly.
2) A heavy duty L bracket with brace legs for support. This currently holds my Fibo 120cm at my parents but this will be taken down soon.
3) A SSS-type spider leg bracket with a short 3" pole, like this:
I am favouring option 3 as I think it's a good compromise between aesthetics and stability. I already have two of those brackets, so I don't have to spend £SSS on it.
Thoughts?
And last but not least - where can I get a good quality 3" pole? I have a nice one in the garage that is 2m long but I don't want to hack it up as I am thinking of using it for the 1.8m dish install. The ones doing the rounds on eBay are only 1.5mm thick and I want something a bit sturdier than that. Only need 50cm length, so can't be that difficult to find ... but I can't find it.
Thoughts?
