2.4 meter dish manufacturers in Europe
onpiste
Visit site
does anybody know the names or urls of any large dish manufacturers in europe or eastern europe! I am looking for a similar spec to the channel master, but at a reduced cost. so far I have only found irte, but there must be more! any help would be welcome
onpiste :-righton
Rabbit
EUROPEAN CHAMPIONS x5
Visit site
System1..
Channel Master 1.8m with CM Feedhorn AZ/EL Mount. MTI AP82-TW 0.6dB LNB. Thomson Sky HD Decoder
System2..
Internet TV... Sweden's Telia Broadband service.
Hässleholm,South Sweden
onpiste :-righton
Channel Master is manufactured in the US, and therefore is 'quality' and has an extremely good gain for the relative size of dish. I have recently looked at IRTE, and its a good dish, but you have to buy a 2.4m to match the CM1.8m. Unfortunately the size is far more greater, and personally I think its huge! Then you have to work out the shipping costs of these large dishes, and that is another large cost. There are others such as in Poland ect. Vistit the link http://www.astra2d.co.uk/ and go into there links and manufacturers. There is one there and its reasonably priced, but I think its manufactured in Poland. Other manufacturers maybe SVEC (China mainly Cband), Televes (Spain), Gilbertini, ect.
Generally CM are excellent, but getting the same spec for a cheaper price with the same size dish is problematic. If there is a manufacturer out there who does comply, I would like to know. Hope I was of some help! Maybe not...!
dishdoctor
Hmm, now what seems to be the problem?
Torreblanca ,Malaga
A 2.4 Channel Master dish will cost around 3000 euros.....how many do you want?.......brian
deepbluesky
Terratec T-Stick+ (DAB+)
Stuttgart (48.79N/9.19E)
Comparable quality to Channel Master should be the following ones:
Patriot, Andrew, MWO, DH
Hope i haven't forgotten any producer but since these are used mainly by professionals don't expect low prices.
onpiste
Visit site
Well investigation has found three new companies Supral, Laminas and Hollstar. the supral is a single piece of alluminuim, and the others are 2 part vertical composite ones like channel master.
I am investigating the performance of these, so if anybody has experience I would like to know any helpful information
donald1209
South-east of Poland
There is Laminas in Poland www.laminas.com.pl
They manufacture the dishes 1.0 to 2.4 m offset. Material GRP .
In a few weeks they start with new 2.7 offset.
