30 w hispasat help
K
kinghippo1977
Likes
sony bravia 32 lcd
techonomate 1500
85cm motor dish
manchester
#1
hi all please help im a newbie
i have a technomate 1500 85cm motor dish , i need help getting on 30w, i select the satellie from the list and the signal is very poor i have tried moving it west and east and the signal does not improve, can you give me any pointers to get the channels please thanks in advancei
R
Rage9
Next Level L1nux
Likes
HDTV
Sky UK HD / Italy HD
Try moving it down a bit.
K
kinghippo1977
Likes
sony bravia 32 lcd
techonomate 1500
85cm motor dish
manchester
#3
can i do this via the motor or by moving the dish manually?
thanks
Robbo
Robbo
Retired Mod
Likes
5
Gravesend,Kent,UK
#4
Are you using USALS?
You should not adjust the dish manually while at 30W, as this may mal-adjust it for picking up the other sats.
Assuming that your pole is perfectly vertical and the latitude/elevation
setting on your motor is correct, I recommend that you position the
motor to Thor 1W and re-check that your dish is aligned properly.
K
kinghippo1977
Likes
sony bravia 32 lcd
techonomate 1500
85cm motor dish
manchester
#5
a pro fixed it for me and i can get all other satellites. i do not know what usals are im sorry,
K
kinghippo1977
Likes
sony bravia 32 lcd
techonomate 1500
85cm motor dish
manchester
#6
still no joy, i cant get thor 1w either
any other tips guys?
H
homerjay
Likes
Spiderbox 9000HD, Super DARK MOTOR, 80cm Dish, SKY+ HD, HTPC w/7MC
Chorley, Lancs
#7
can you get any sats?
sounds like you need to start from scratch
Likes
1,296
#8
Did you set up the dish and motor and have you ever been able to get these sats?
K
kinghippo1977
Likes
sony bravia 32 lcd
techonomate 1500
85cm motor dish
manchester
#9
i can get 19.2 e. 16.0 eutelsat(digialb). 13.0 e, 28.2 e. turksat 42,
so i get quite a lot, a company fitted it for me as i paid for digialb(gold package) but no joy for hispasat
thanks for replys
