moosegoose
bog standard
- Jul 2, 2007
- Age
- 61
80 cm dish hh motor teco tm1000 dreambox 7020
cas 3interface
dragon cam.promax tv explorer 2.
- norwich
hi i was looking for a external amplifier with up to 4 ports which can be remotely powered from 4 town houses. so they can all use 1 aerial. i have used antiferance 4 way mast head with variable gain which can be powered from any output. but can all so be powered from all of them although this is not what it was designed for. i checked with antiferance and the said although it was not designed for that it has been used for that application with no problems. my concern in using this amp in future was a recent artical on sharing satellite dishes and and problems if the electrical supply is not on the same phase. i not sure if this will effect a shared amp powered remotely from 4 separate dwelling. i have done a goggle search with no luck.
