48E Afghansat 1/Eutel 48D
tempo
47.5N, 42.2E / Russia
47.5N, 42.2E / Volgodonsk city, south-west Russia
Piltdownpaul
No.1 Spike Milligan Fan
Nothing here from 11231.
Footprints!
Fixed: (in use for Afghan mux I suppose)
Steerable:
Hamid19
Boras
Hotbird13,Astra/euro28,
Astra19 and Thor08
Boras
Kveys
Southern Finland
Sorry Hamid19, nothing here anymore. It was easily watchable at first but they maybe done little fine tuning for beam?? or something else but after may, no signal anymore. Nothing changed here at my qth same time. But anyway although it would be 6-7dB here, it easily mean that you should put quite large dish. And now when I cannot get any signal anymore, you must use more than 2m dish (maybe a lot bigger?).
So, as Analoguesat said, internet streams are probably best way to watch Afghan channels...
Hamid19
Boras
Astra19 and Thor08
Boras
ok!
2m dish to get here looks difficult and I tought I could get those channels beacuse there is big difference between watching on Internet and on dish satalite quality but if possible still I want to get this beam/Ku band fix beam, I have 120 size dish now at home and what is this as satbeams shows In city
Azimuth & elevation in Boras, Sweden: 140.3° & 17.7°? What does this mean?
Theres also a big difference between watching on the internet and not watching at all........
140.3 is the direction to aim it, 17.7 is the elevation above ground level.
I rather doubt you have any chance though on a 1.2m dish
On 53° East (Express AM22), the following Afghans can be received easily:
1 TV, Batur TV, Mitra, Rah e Farda and Tamadon.
On 13° East (Hot Bird), there is also:
RTA, Ariana TV, Payam-e-Afghani
Then there is only few extra left on 48° East.
The satbeams azimuth and elevation values, is only about where to point the antenna.
That says nothing about the signal over there. Forget 48° East.
Hamid19
Boras
Astra19 and Thor08
Boras
Ok thanks guys and I should forget now Afghansat 1 48 east!
pontiend
Contibruter
south yorkshire
I was getting bored so set a scan of on 48East.
It came up with a weak transponder.I do not know where it is from.
Looked at all the near sats. At the usual places but cannot find it.
It is still banging it down here.:(
11493H 2420 32psk.3/4.
TBS 6925 100 cm Dish
11493 H 2420 it's from Intelsat 10 @ 47.5° East and already on Flysat.
Archived-1
Persona non grata
uk
Thank you for the information Ray, I have not had a play round here for a while, I will take a look at some point I can move your post to 47.5 E thread or you cold just re-post it here,
http://www.satellites.co.uk/forums/threads/47-5e-intelsat-10.158376/page-3
