56E (Direct TV 1R)
Thanks Pride! Will be good to see. Don't forget it's circular polarisation so you might need to play with a polariser plate in the Ku band LNB.
mehra
SATELLITE SNIFFER
2 Dish Tv Zenega STBs | 1 DM 800 HD Clone | 180 cm TX Rx Fibre offset Dish Antenna |
india
friends I am not stealing the thread,just placing a query. Kindly help. Here in India I am getting 12303 H 12000 from Bonum 56 E about 65-70 % signal. But a strange thing happens that even the finest tuned dish will slowly start losing signal in about 1 hour after tuning, and will drop to zero soon for next 24 hours. Again tomorrow at the same time when dish was tuned yesterday the same signal will start coming from weak and grow strong and cycle continues. Please give some valuable comments. What I got in best scan is this.
This is normal for this satellite. It's inclined 0.7 degrees so it wobbles throughout the 24 hour period. It's not very noticeable in the centre of the footprint on smaller dishes but the effect is much more pronounced at the edge of the beam.
mehra
SATELLITE SNIFFER
india
thanx sir. but what is the best way out to make sure that i dont have to adjust my dish every hour. moreover i am using universal sharp lnb (not special circular one) with a prodelin 180 cm offset fiber dish. woul i be able to get stable signal at
Latitude: 30.1964°
Longitude: 74.9466°
i wish to receive direct 1r
please help me. thanks in advance.
You need to get a circular LNB - it will help a lot. Or put a plastic plate inside your current LNB.
A new satellite is scheduled to go up there next year, until then, you can't do much.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Could you show pictures of your Prodelin? I became a fan of those antennas some time ago. I also have temporary installed Sharp LNB.
mehra
SATELLITE SNIFFER
india
my pleasure
mehra
SATELLITE SNIFFER
india
but sir its impossible to align the dish every hour. any "good" time for alignment when satellite is at central position ?? and yes i have inserted a credit card piece inserted inside lnb. please guide.
RimaNTSS
N-E from Riga
Nice picture. Could you add more: from the back of antenna and also more closer look at LNBs part. How did you find focus of antenna to install central LNB?
mehra
SATELLITE SNIFFER
india
I got the lnb tripod alongwith the dish.
Latitude: 30.1964°
Longitude: 74.9466°
Theres nothing you can do - the satellite is moving up and down off the arc over a 24 hour period.
You can see when shes on the arc using this link
http://www.n2yo.com/?s=25937
Over on the right look for when the latitude is very close to zero.
hairybadger
Bricoleur
46.1N 6.4E
see sig
Didn't I read something about elevation control on another thread?
Yes - 2 axis dish control, not impossible but hardly ever bothered with.
mehra
SATELLITE SNIFFER
india
thanx for reply, sir. but i still don't understand what the actual subscribers do, that i am missing ?
Subscribers will be using smaller dishes as they are in the target area.
Smaller dishes = larger acceptance angles of incoming signals.
Chances are they wont notice much fading in and out until the inclination gets up past 1 degree..
mehra
SATELLITE SNIFFER
india
thanks for all the info and link that solved all the mysteries that let me on roof all the night for last 5 days. i can sleep today. Will it be ok if i align the dish when the sat is in mid of the path vertically ? Otherwise, pls guide.
You will get the signal for a couple of hours twice a day as the satellite wobbles up and down on its elongated figure-8 orbit.
mar-val
Slovakia,Zilina
Bonum is one of my favorites...of course I have declination control actuator.
Here is TLE chart-lat.,long.,time.
mehra
SATELLITE SNIFFER
india
thanks for all the guidance. I'll try tuning dish when latitude value is 0.
pride21
Sandown Isle of Wight
hi all I did a fine tune up of dish it was out of bonk since the winds we have had, the results of doing this gave me better gain so I thought I would give this sat a go it was 3.30 pm to my surprise I got 12384H 8 channels at 37% quality with ordinary lnb all scrambled the only transponder with linear lnb,so I changed to circular lnb 12384H jumped up to 51% quality and I also got 12443H 7 channels at 40% quality.12224R was showing 53% quality no lock also 12283R was showing 50% quality also no lock,tried this sat at 1.30 am got the same transponders started to fade at 2.30 am because of the incline.
