8 ft offset fibre dish
nitinm8
nitinm8
8ft c band ,4ft ku band dish,8ft ku band offset fiber dish with winersat receiver& melbon fta receiver& videocon d2h receiver
NASIK,INDIA
hello,
i am in nasik. i have 8ft ku band offset dish. can i receive ku band signal of eurobird9/ hot bird or any in nasik easily.plese help me . i am waiting for reply.:confused
thankyou
Moradabad
Moradabad
SAT SPECIALIST INDIA
One 12 Feet Heavy Antenna, one 10 Feet Double Rib Antenna
Dreambox Dm500S, DM 7025. HD Receiver,Envision,
Eurostar receiver, 4 Dual LNBS, 5 PFA Lnbs
india
Yes you can easily get Eurobird 9 and 15.8 east, if you need further guidance ask, by the way where you got this 8 feet offset as 8 feet new offset is not available easily,
but hotbird you wont get there
M
mohit45
dd dth on 90cm dish and 8ft c band dish with zenega and telecab recievers.
kullu himachal
what is the cost of 8ft offsat dish n from where u got it
nitinm8
nitinm8
NASIK,INDIA
which signal of (eurobird9/15.8 east ) is strong signal .
the dish is 8ft fibre dish like "ATM " dish .reply me
Moradabad
Moradabad
india
try with this tp 11727 V 27500
S
sanjay12391
bihar
CABLE DISCUSSION
india
Moradabad sir, 12 feet jams dish bettar ya yanhik fibar dish bettar. Pls reply . I want contact u.
Aafancier
Aafancier
Zenega 95010-07073 Homecast, 42 E, 25.5 E, 95 E, 93.5E, 75E, 90E, 105.5 & 100.5 E C band, FTA STB, 90 cm ku band Dish, 120 cm Dish, Dishtv 70 cm Dish, Sun Dish, Big tv Dish. Di-sec Switch
India
Fiber dish is Better..........
S
sanjay12391
bihar
CABLE DISCUSSION
india
but sir jams metal dish 18000 for 12feet yanik fibar dish for 12feet 24000. What cost Good qualiti fibar dish of 12feet? Pls give me shop address.
B
babbuxp
Markson FTA stb,8feet mesh dish, computer with core2quad processor ,Leased Reliance high speed net.(42 mbps).
allahabad,UP,India
can any body tell me that is it possible to get any euro/hot bird in allahabad,east UP..area if then whats dish size req. ?
Moradabad
Moradabad
india
Sanjay its better to buy some branded dish if you really need Fiber, Check ur pm.
Neither Yahnik nor Jams its a very old Mumbai company which made its 1st India fiber dish in 1990...
They are supplier to all Doordarshan centers there 11 feet fiber dish is 26000 bargain and ask for 22000...
V
vjkumar
16 feet motorised dish for c and ku band,6 ft offset dish,6ft motorised off set Dish,DM500,DM800 HD, Spiderbox 7000HD ,Tecnosat 1100plus,MetaboxIII,(146E to 25.5E)
Coimbatore -India
Hello friends
Moradabad , for this price you can fabricate motorised offset mount with dish.
I attach some photos for guidence.
Moradabad
Moradabad
india
Hats off to you my friend, you are really master in engineering these things.
Hope you tune 9E & 16 E on your new 6 feet off ant....
Moradabad
Moradabad
india
frankly speaking Kumar your motor setup is far advanced than that comes with the New FRP antenna, & I hope it will be cheap to compared to the branded one.
B
babbuxp
allahabad,UP,India
whats its cost man i?ts really awsome .
V
vjkumar
Coimbatore -India
Hi Moradabad
These motors are of truck wiper motors which you will get it from the Auto electrical repair shops on road side, only thing you have to do is to ask for extra winding ( ie the winding wire gauge should be higher than the normal) then the load taking will be good. Also these motors will work for years. One in my 16ft motorised working for he past 22 years.
The cost depends on your ability to negotiate between Rs 800 to 1000.
Any help needed in this plaese PM I will share the details.
The sensors are available in local electronics shop. The controller ,yes , it is tricky and easy if you know any electronic guy.
V
vjkumar
Coimbatore -India
Hello Moradabad
Yes I will try those satellites and post results.
I will post the photos after the dish is mounted.
K
kunwarbakshi
Core 2 Duo, 4GB, Xbox 360, Nintendo wii
New Delhi, India
vjkumar said:
Hello friends
Mr. Kumar, This is impressive. Awesomely done. Why don't you try to put it in a commercial platform because I reckon many ppl on this site would like to have this.
K
ketineni
8ft mesh dish, i7 system
hyderabad
guys, can you please suggest where i should purchase quality 8ft fiber dish, how much more signal i can get compared to a 8ft mesh ?
D
dspdsp
DishTV DTH
Zenega 1004s Receiver
90cm offset Sharp dish antenna
india
You will get it at Koti, Near Sultan Bazar, Hyderabad.
K
ketineni
hyderabad
thank you, i hope that you are talking about fiber dish which supposed to give more signal
