80 cm dish, Irdeto 2 cam, humax C5100 Reciever...what next??
santheman
I have just bought a second hand box with a dish and card, where shall I point my dish to get the most channels ie football, mature content etc?? I have one LNB...do I need to program the CAM, how do I program cards for it???
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
I really think all the info you require is on this site. Have a good read through first santheman and then we can help you with the finer points.
santheman
Ok, I have had a read, know how to put the dish up, I probably want to point at hotbird - Is this the bes for starters.
Also if I have a irdeto 2 cam without a card, does this mean that I can pick up irdeto 2 FTA channels, or do I need some sort of card to use this CAM?
Which is best - Hotbird 13 degrees or Astra 19.2 - can I get both with an 80 cm dish?????
Any help would be great!
You can set up the dish with two LNBs to receive Astra 19.2 and Hotbird (depending on where you are) should be some information in the FAQs and How to section, if not best to ask the installation questions in the Multisat Systems forum when they arise.
Not sure how much use the Irdeto CAM will be at the moment, unless you are using a season interface and emulator software on your PC.
Which receiver do you have?
santheman
I have a Humax 5100C receiver. Should I start with Hot bird or Astra?? Which do you recommend
If you start with Hotbird, then you will not need to move the dish to add 19.2.
To determine how useful the CAM is you will have to interrogate it in the CI menu
Then check it against 2Olds post on CAM info
iceboy
what you need is a twin lnb, it will catch hotbird and astra both, and for the channels you can use an magic module.with latest updates.................THE ICEEEEEEEEEEBOY,
Ah, you mean a monobloc LNB, a twin LNB has two universal outputs pointing at the same satellite, a monobloc has two universal outputs pointing at two preset satellite locations, most common in Europe being Hotbird 13E and Astra 19.2E. :)
