Abandoned dish
superpascu2
ATLAS HD100 - ASTRA 19,2 + HOTBIRD 13 + 28,2 1.2m famaval
Alicante
fwuky6
Does anyone know this dish?
Abandoned in my roof for 20 years.
It used to belong to french people for analog system
20171021 185057
Terryl
Custom built PC
Not seeing a photo....??
superpascu2
Alicante
Must be 1,4m
Once a saw one like this one in América.
"Galavision" is printed on it
superpascu2
Alicante
Thank you Lazarus!
I attach another dish not used in the comunity, we used to use it for astra 19,2 in analog system. Look at the lnb, 2 cables. Maybe for V&H? First time I have seen it.
20171021 185310
Had a logo of "tagra sat" printed on it
With a bit of tender loving care, a new lnb and some replacement cabling there is no reason why that dish cant be bought back into use. Get some penetrating lubricant and give ALL the nuts & bolts a good squirt. After 20 years you can expect some of them to be seized solid so you may want to source a selection of stainless steel replacements
Whilst you are at it resurrect that sad old 60cm thats pointing at the ground behind the big one! :D
On the full sized pic the dish also has a very faded and badly applied BLUE SAT logo across the top edge and possibly a phone number above the GALAVISION logo
Phil Cossack
to be set up
Wiltshire
Tel No. 965 631 249
Blue Sat SL based in El Compello , Alacant ( Alicante )
Google is your friend!
superpascu2
Alicante
Yes, blue SAT was the company which intalled the dish here in Alicante.
I remember It was already old when the fix It. The is no lnb, the plastic is burnt by the sun
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Must be 1,4m
I doubt it! Most likely, it is only 1.2m. Without seeing its back, and knowing exact dimensions, it is hard to say the name. But, from what I see, and hear that it is made of plastic, I suggest it is Prodelin (Echostar) dish with offset angle of 22.7*. Nice find.
superpascu2
Alicante
Yes, It is not aluminium. It is a kind of plastic
You may find the lnb holder is very brittle after 20 hot summers spent baking in the sun so dont be too rough with it.
Fibreglass with an embedded mesh reflective surface.
Phil Cossack
to be set up
Wiltshire
Thank you Lazarus!
20171021 185310
Not so easy to find, but Tagra Sat is a registered mark of Tagra Coop which is Spanish registered, good old Google!
Apparently they make ( or sell ) everything from Satellite dishes to speakers and all manner of radio equipment.
Información sobre la marca TAGRA-SAT registrada por TAGRA COOP
superpascu2
Alicante
Yes, crashed years ago but sure this was not made from them, maybe they imported.
It is 1,8m at least.
Can anyone upload the picture correctly as lazarus did with the other one.
Sorry about that
Trust
Nijmegen Netherlands
A closer look at the lnb clamp will tell the truth
Prodelin used a metal clamp for their dishes (22-24mm) plus their own feed for the Echostar systems (that were only 1m) so it is not one of those.
In reality an image of the back of the dish, with the mounting points and the ribs will determine the true ancestry.
RimaNTSS
N-E from Riga
You might be right! However, from given picture it is hard to see enough details. Another picture from the back could be useful, and especially in case of plastic dish.... they have undoubtful pattern of the strength ribs. Prodelin 1.2m does not have any screws going through its face, and on this dish I do not see any screws ether. 20171021_185057 (337 x 600) (Medium).jpg Also, side-feedarms connect to the dish from side, as it is done on 1.2m Prodelins. LNB-holder.... well, I do not see it on the picture at all :eek:
So, I still insist it is Prodelin!
The feed system is black though, so still unlikely as Prodelin was alloy/metallic.
The accurate dish parameters (horizontal and vertical ) woud help as well.
