1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Top Tip ABERTIS TDT-SAT (30W) HOW-TO GUIDE (FOR EDUCATIONAL PURPOSES ONLY)
Discussion in 'Satellite PC Card Receivers, Internet by Satellite' started by MCelliotG, Dec 24, 2016.
  1. MCelliotG
    MCelliotG Regular Member
    May 10, 2015
    356
    538
    My Satellite Setup:
    TBS 5925, EDISION OSMINI, DM800, IXUSS ZERO, MABO 130X144, DRAGONSAT DS3000 LED MOTOR, INVERTO BLACK ULTRA TWIN LNB
    My Location:
    Thessaloniki, Greece
    Hmmm, maybe I'll try running this code in the scripts area of astra-sm and hopefully that will work on all architectures as well.
    Edit: not working! :(
  2. Adam792
    Adam792 Specialist Contributor
    Sep 5, 2009
    436
    245
    My Satellite Setup:
    Dishes: 80cm (5°W/4.8°E), 80cm (30°W), 60cm Zone 2 (13°E/19.2°E/28.2°E)
    Receivers: HTPC (Intel i3 processor, nVidia Graphics, and TBS6905 4x DVB-S2 PCIe tuner card) running Ubuntu with Kodi/TVHeadend, Wetek Play2, Skybox M3.
    My Location:
    Worcester
    Yes I can post the config files! Obviously everything except for the keys which you'll have to find and enter yourself.
    I'll have a look later when I get back from work! :D
    ljalves likes this.
  3. ljalves
    ljalves New Member
    Apr 17, 2017
    7
    My Satellite Setup:
    TBS6909 + TBS6205 + TBS5520 - 13E, 30W
    My Location:
    Portugal
    Thank you!
  4. ahstar
    ahstar Member
    Dec 24, 2016
    10
    4
    My Satellite Setup:
    sky star2 ex hd
    My Location:
    Marseille
    Thank you Adam792
    After many attempts now I see numbers in the field "uncorrected blocks" tvheadend
    I think it is missing only the correct key ???
  5. ahstar
    ahstar Member
    Dec 24, 2016
    10
    4
    My Satellite Setup:
    sky star2 ex hd
    My Location:
    Marseille
    How to run Tvheadend on Windows 10
    I have downloaded from Windows Store , but I did not know how it works
  6. Adam792
    Sep 5, 2009
    436
    245
    My Satellite Setup:
    My Location:
    Worcester
    If it's working properly, try and stream a channel and you should see numbers in the "bandwidth" column on the status page. Ignore Uncorrected Blocks, Transport Errors and Continuity Errors as long as the numbers aren't increasing as you watch the screen!
  7. Adam792
    Sep 5, 2009
    436
    245
    My Satellite Setup:
    My Location:
    Worcester
    No problem!
    I've attached my Hispasat muxes and services files (muxes.zip). To use this, you must -
    1. Create a new network in TVHeadend for 30W. Don't add any muxes.
    2. Go to /home/hts/.hts/tvheadend/input/dvb/networks, and there should be one folder with a string of random characters as the title for each network you've added. The config file in each directory will tell you which network it is. Find the Hispasat one you've just added - this is easy if you have only added one network.
    3. Copy the "muxes" folder into the Hispasat directory. The folder
    should now contain the "config" file and the "muxes" folder you've
    copied (along with the files inside it!)
    4. Now restart your computer or TVHeadend. You should have all the TDTSat Hispasat muxes and the fake services in the "Services" tab!
    5. tdtsat.zip contains some example script files to add as streams as an IPTV network as I've described already. You'll need to change "python3.5 /storage/tdtsat/livetsstrip27.py" to the directory you put the python file into. Make sure you set permissions to 755 for all of the sh files and the python file!
  8. ahstar
    ahstar Member
    Dec 24, 2016
    10
    4
    My Satellite Setup:
    sky star2 ex hd
    My Location:
    Marseille
    I created a new network and copied the "muxes" folder and restarted the computer but nothing appears
    muxes tab 0 Services tab 0 !
    I do not know what is the problem
  9. ljalves
    ljalves New Member
    Apr 17, 2017
    7
    My Satellite Setup:
    My Location:
    Portugal
    The signal strength is off the scale and there is missing info for some cards.
    What drivers TBS are you using? TBS closed source, my open source drivers or TBS branch from my git?
    Thanks for the config files, as I suspected my config is right and I only miss the correct keys. Too bad...
    I was only doing this for fun anyways :)
  10. ljalves
    ljalves New Member
    Apr 17, 2017
    7
    My Satellite Setup:
    My Location:
    Portugal
    What version of tvheadend are you using?
    If you use latest tvheadend git it should work - older versions use a different config structure (not compatible).
  11. ahstar
    ahstar Member
    Dec 24, 2016
    10
    4
    My Satellite Setup:
    sky star2 ex hd
    My Location:
    Marseille
    i use Tvheadend 4.1-1284~ga5085c8 - Ubuntu 16.04 LTS
  12. ljalves
    ljalves New Member
    Apr 17, 2017
    7
    My Satellite Setup:
    My Location:
    Portugal
    4.1-2528~g9fca900 here and it did work
  13. Adam792
    Sep 5, 2009
    436
    245
    My Satellite Setup:
    My Location:
    Worcester
    I think I've seen your drivers! I thought I recognised your username!
    I'm away in Greece at the moment otherwise I'd check. They're definitely open source ones though I'm using - I think it's the tbsdtv ones. They show the signal in dB which I like.
  14. ahstar
    ahstar Member
    Dec 24, 2016
    10
    4
    My Satellite Setup:
    sky star2 ex hd
    My Location:
    Marseille
    Adam792
    please can you give me How to Run tvheadend on Windows 10
  15. Analoguesat
    Analoguesat Administrator Staff Member
    44,060
    7,083
    My Satellite Setup:
    Skybox F3
    My Location:
    You have to do a lot of the hard work yourself on this forum.
    BTW Ive already asked you once to change your location in your profile to a proper location. We are easy going here but we do ask folks to fill their location in properly - we are a tech forum and it could be important if you ask a reception related question.
    Chris1979 likes this.
  16. ahstar
    ahstar Member
    Dec 24, 2016
    10
    4
    My Satellite Setup:
    sky star2 ex hd
    My Location:
    Marseille
  17. Adam792
    Sep 5, 2009
    436
    245
    My Satellite Setup:
    My Location:
    Worcester
    You can't. It's Linux software!
  18. Adam792
    Sep 5, 2009
    436
    245
    My Satellite Setup:
    My Location:
    Worcester
    I've just realised, this is probably because the script is python3 and Enigma probably needs the python 2.7 compatible version. I'll post that later! It doesn't need many changes.
    Sent from my SM-T580 using Tapatalk
  19. Adam792
    Sep 5, 2009
    436
    245
    My Satellite Setup:
    My Location:
    Worcester
    This code works!
    import sys
    packet = sys.stdin.read(188)
    pid = int(sys.argv[1])
    while sys.stdin.read !="":
        tspid = ((ord(packet[1]) & 0x1f) << 8) | ord(packet[2])
        tsaf = ord(packet[3]) & 0x30
        if tspid == pid:
            if tsaf == 0x10:
                sys.stdout.flush()
                sys.stdout.write(packet[4:])
            elif tsaf == 0x30:
                aflen = ord(packet[4])+5
                sys.stdout.flush()
                sys.stdout.write(packet[aflen:])
    I've saved it as abertis.py in the scripts directory. With the astra.conf file like -
    make_channel({
      name = "Abertis PID 2025",
      input = {
      "http://localhost:8001/1:0:1:BD1:EA74:1:CE42BD6:0:0:0:",
      transform = {{
      format = "pipe",
      command = "python /etc/astra/scripts/abertis.py 2025",
      output = {
      "http://0.0.0.0:9999/abertis/pid2025",
    This works on my Wetek Play with Enigma2 OpenATV 6.0 (ARM architecture). It stutters a bit on most of the channels because the box isn't powerful enough (I get identical stuttering in TVHeadend on LibreELEC with this same receiver and script), so on a slightly more powerful receiver it should work perfectly!
  20. MCelliotG
    May 10, 2015
    356
    538
    My Satellite Setup:
    My Location:
    This is amazing, thank you so much! I have the bins for arm and mipsel but this code could work in sh4 too, there's a Golden Media I'd like to try. For the moment it didn't work on my Osmini (no picture) and SDG but I will keep trying.
    xopaxopa and Adam792 like this.
Share This Page
Click here to support our sponsors
