Adult Channels in DUBAI , Middle East, UAE
khurshid
i will give u latter
Hi Guys,
Kindly email me how to update receiver TOPFIELD MODEL TF4000FI if possiable with file.
Please help...will appreciate your replies to iambreakingtherulesagain@nomail.com.
Thanks guys and have a nice day
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
This is a self help forum, nobody will Email you anything, so do not post your Email address again as it is against the forum rules. The reason you only see the picture for a short time is that the keys are rotated every few minutes so unless you find an emulator for your stb that accomodates the key changes you will not be successful.
Mickha
North West
Just to add to Toppers post, if your receiver is patched you will need to tune it to Sci Fi France, or other channel using 10873 V 27500 to allow the keys to update, once opened you can then tune to the rest of the channels in the package.
TPS have had the AES encryption turned off for some time so was viewable to most people, but now they've turned AES back on you will need the latest patch, or Diablo cam, to view it, at least for the time being as it will soon be moving satellite.
rizwanrk
Satellite only, no computer
Saudi Arabia
Can any one help me how to install Free-X TV subscription card on my XDream 900 receiver
HB13DISH
Retired Mod
Middle East - Israel
1 - Which encryption option does it have (Viaccess or Irdeto)?
2 - Is there a CAM Slot/slots in your receiver (embedded or CI)?
3 - Do you have an Irdeto or Viaccess CAM (depending on Q1)?
4 - If your receiver is FTA, then you can't.
HB13DISH
Retired Mod
Just looked at the Dreambox 900
It has embedded Irdeto CAM
If you bought Viaccess card then it will not work
If it is Irdeto, then just insert the card with the chip down.
rizwanrk
Saudi Arabia
1-Irdeto Embedded
2-CAm slot Embedded
It was working perfectly allright and after fresh scann its gone.
HB13DISH
Retired Mod
rizwanrk said:
1-Irdeto Embedded
2-CAm slot Embedded
You should have mentioned this before.
Scanning shouldn't cause any problem.
Try to shutdown the box, pull the power cord, wait few minutes, plug it in, switch on and see what happens.
rizwanrk
Saudi Arabia
Irdeto embedded
• 6000 channels memory
• Input Frequency
• 950-2150 Mhz
• Support EPG
• Multilanguage function
• Easy graphic menu
• Teletext supported by VBI
• Digital Tuner with loop-through
• Last channel memory
• Multi-search
• Easy & fast software upgrade through RS 232C Port
• MPEG-2 Main Profile at main level
• Dolby Digital Audio
• Supports Game
• DiSEqC1.0 and DiSEqC1.2/1.3 cintrol compatible
• Tuner sharp
• 2 MB flash
• STI CPU
HB13DISH
Retired Mod
If you still have problems with your card, try deleting all the channels from the channels list for this package (Free-XTV, Xdream, etc.) and then rescan their TP frequency.
rizwanrk
Saudi Arabia
Delete will not delete the channel permanently????
rizwanrk
Saudi Arabia
My receiver is XDream 900 not Dreambox 900
HB13DISH
Retired Mod
I don't think so.
Test this first on a channel that is not impotrtant and note it's frequency, Pol, SR, FEC delete it and then rescan.
prince27
TOPVISION
saudiarabia
where from we get that in dahran?
iyassin
LAN Connection
Palestine
uthay71 said:
i bought ebox receiver (which i cannot find website supporting it), but for the time being it just work fine as i can watch multivison, xxl, playboy, private spice (03.00 localtime abu dhabi). note: those channel after "opening" (langguage setting press code 2528, and saving data...go to channel french 5 updating code by press 8888 that's it ! happy wathing.....all those channel (xxx) begin from 01.00 am to 6.00am
Can you help me? I am looking to buy this receiver. Can you tell me where and how much and if you pay a subscription or free? thanks.
