AGC problem on dreambox!
Kargax
dm800
lux
I wanted to change lnb holder yesterday, when i did that and connected the 2 lnb heads again the AGC showed from 0-100 depending how i moved the cable behind the DB.
If i disconnect the cable from the diseq and put one end into the dreambox it shows 0-100 depending on how i push it in and let it be in one spot. Has anyone experienced this problem?
I am starting to think the In connector is broken but then it would not show any signal at all...
Thanks for any help!
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Sounds like you may have a broken central core on you cable or not enough central core protruding from the F connector to make contact
Kargax
dm800
lux
I have got a signal on one lnb and searching for channels right now, but its not finding any, i had 99% AGC and 93% SNR, but i couldnt find any specific channels through SATfinder.
I have tried exchanging the cable and its the same thing, i have also tried without the Fconnector
You tried it without the f-connector??? Why - it certainly wont make good electrical contact without it.
You have folded the excess braid back along the pvc insulation & screwed the f-connector over it havent you.
Have you unplugged it from the power supply before changing over the cables ?
Kargax
dm800
lux
I have not done that, but i have done a reset of the dreambox after changing...
Analoguesat,
I dont really get what you mean with screwing the fconnector over , i just tried once without the fconnector...
Analoguesat,
When you put an f-conn onto a coax cable you have to fold the braid back over the pvc insulation, then screw the connector over both - if you cut the braid off completely you wont get a proper electrical circuit.
And not using a connector at all, even if you were to get decent electrical contact, would affect the impedance of the cable and also destroy the shielding.
