Almost there with DB5620S
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
homerjay said:
pushing up doesnt do anything?
You have to press the 'channel up' button at the boot screen, and keep it held until the LCD displayes 'Flash Erase' (about 5-10 seconds).
You're probably way past this stage now... LOL
Striker10
Visit site
top of flats, london
Have you opened it up at all? When it hangs does it hang on the bootup screen (with image on screen) or does it go onto a black screen? I can tell you i have a null modem cable 9 pin f-f connector and when i initially tried it on my computer, it didn't work. Try both com ports, then try someone elses computer if you can. I have limited knowledge.... :D of bootloaders, but going by what everyone else says you should be alright. Keep trying and goodluck.
homerjay
Spiderbox 9000HD, Super DARK MOTOR, 80cm Dish, SKY+ HD, HTPC w/7MC
Chorley, Lancs
'channel up' definatley doesnt work, i just stays on the boot screen.
the the cable i have is 25pin m-m with a converter m-f 25-9 at each end, whihc is probably not the best.
gonna go buy a striaght m-m 9 pin cable today and try again tonight...
pant
gameboy said:
If the LCD is working with information on the image on it I'm sure the bootloader is OK...
In my case the 5600 boot was scroling but the bootloader was corrupt.Had to send it back for repair.The only thing to be sure about the bootloader is trying Hyperterminal.
john_graydon
Dublin....Ireland
homerjay said:
just come to it now, after being out all day and the damn dunt wanna turn on???
flick the on switch at the back and the "the_hydra zeus" boot screen appears and "5600 boot" is scrolling across the LED display but its just stuck there???
any idea's?
Thought you lads would be up and running by now. A few questions.
Which image are you using, Is your box connected to the Net via ethernet cable.
If you keep changing images all the time you will get mixed up with the function buttons and what the image can do. I loaded the Hydra Anaghrad on the 5620 2/3 months ago on one of my mates boxes and the Zeus a few weeks ago on another. They are all working fine at the moment and no reason to change them with new images.
My advice to you is get your box set up to the net first, Pick an image that we all know well like the hydra, the panel needs to be updated by using ftp so you can download cams & ke*s.
You dont need to be using the null modem cable as this leads to all sort of problems like flash erasing, holding buttons on receivers.
Download flash wizzard pro and use this. You DONT need to hold buttons on the receiver after you flash with FW Pro. + it only takes 2 mins to flash an image.
At this stage you know how to set up your sats. Back up your image and settings. Then go and explore other images and if you mess up just load your saved image and you will be back to normal.
On the 5620 there is limited var space so only load 1 cam (Newcamd 5.28) and 1 set of keys. Reboot and happy viewing.
If your having trouble using ftp or flash wizzard pro setting up sats or motor con fig come back and we will sort you out.
Manually find Sats 1st is another tip I would reccommend as some Images Go To Function dont work properly.
Here is a guide on how to find them I did for my mates some time ago, it might be usful.
homerjay
Chorley, Lancs
Hyperterminal?
also, whats the returns process?
pant
When you connect to your box through Hyperterminal and you get something like this:
Dreambox DM5620
Dreambox DM5620 - Bootloader V.1.00 - 04.10.2003
------- System Info --------
Processor speed = 252 MHz
EBIU speed = 63 MHz
Amount of RAM = 48 MBytes
--- Device Configuration ---
Power-On Test Devices:
000 Disabled System Memory [RAM]
002 Disabled Ethernet [ENET]
Boot Sources:
001 Enabled Application in Flash [FLASH]
local=0.0.0.0 remote=255.255.255.255 hwaddr=0009341ea077
003 Disabled Serial Port 1 [S1]
Program exception
SRR0=00000000 SRR1=00000000 ESR=00000000
Die ... :-(
Then your bootloader is corrupt but if you get something like that:
Dreambox DM5620
EBIU speed = 63 MHz
000 Enabled System Memory [RAM]
002 Enabled Ethernet [ENET]
Boot Sources:
001 Disabled Application in Flash [FLASH]
local=0.0.0.0 remote=255.255.255.255 hwaddr=0009341ebc51
Baud = 9600
Automatic Boot: Disabled
1 - Toggle Power-On Tests
2 - Change a Boot Device
3 - Change IP Addresses
4 - Ping test
5 - Change Baud Rate for S1 Boot
7 - Toggle Automatic Boot
D - Display Configuration
S - Save Changes
0 - Exit Menu and Boot Application
Then probably you are ok.
homerjay
Chorley, Lancs
been and bought an new null modem cable and i can connect using dreamup. YAY!!!
in process of uploading an erase image at the minute, so hopefully i will be back to true factory settings following this...
homerjay
Chorley, Lancs
somebody is having a ****in laugh at my expense!
tried uploading erase.img and now i get "5600 boot" but a black screen
AND
now i cant use dreamup AGAIN!
how do i use hyperterminal, what are the port settings? do i just use default settings, coz when i do nothing happens?
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
Waht's erase.img?
If I remember you just select erase from the DreamUp window - don't load anything until you get the OK message.
Then upload the latest official image off the website 1.06 (5620) and try that.
homerjay
Chorley, Lancs
downloaded erase.img from dreambox net oz...
it managed to connect through my new cable, but only (i think) coz the box had been off for 24hrs. now i cant connect again?
homerjay
Chorley, Lancs
managed to get this from hyperterminal now, by disconnected all other cables
Dreambox DM5620
Boot Sources:
local=0.0.0.0 remote=255.255.255.255 hwaddr=0009341ed758
Baud = 9600
Automatic Boot: Enabled
4 - Ping test
S - Save Changes
so now what?
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
try...
IP 10.0.0.2
Sub 255.0.0.0
homerjay
Chorley, Lancs
gameboy said:
try...
IP 10.0.0.2
Sub 255.0.0.0
where do you want me to put that?
my router is 10.0.0.2 / 255.255.255.0
my pc is 10.0.0.10 / 255.255.255.0
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
The instruction manual asks you to put these in the DreamUp window under 'use network' option - this may be if you are using an Ethernet crossover cable which make the whole deal faster.
Check pages 36 - 37 of the manual.
homerjay
Chorley, Lancs
my box does not have an ip at the min, so i cant connect via tcp/ip
if i try and change ip through hyperterminal, it asks for a local ip and a remote ip?
anyway, for some unknown reason, dreamup has connected now, so ive clicked erase to see what happens?
homerjay
Chorley, Lancs
right erase has completed, do i reboot and reconnect or do i load the official firmware from here?
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
Load official image then flash erase on startup...
Fingers crossed.
P.S. get the image off the official site twice images from the OZ site have trashed my box!
homerjay
Chorley, Lancs
Load official image then flash erase on startup????
dont ya mean erase (which i have done) then flash official image?
i dont wanna reboot now and realise the box is totally clean of ANYTHING and cant connect EVER again?
so to clarify:
I have erased, so it says flash erase complete. do i now:
a. reboot the box and reconnect the flash original firmware
or
b. flash the original firmware straight away without reboot.
cheers
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
The next thing you need to do is using DreamUp load the official image.
Wait until you get the OK message - it takes longer using the null modem cable only.
