Almost there with DB5620S
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
homerjay said:
all cables removed except power and null modem and dreamup does not connect.
The power cable shouldn't be connected - only the null modem.
Until DreamUp informs you you have a connection - then plug in the power cable.
homerjay
Spiderbox 9000HD, Super DARK MOTOR, 80cm Dish, SKY+ HD, HTPC w/7MC
Chorley, Lancs
1. unplugged everything.
2. plug in null modem cable
3. load dreamup
4. click connect
5. connect power
6. turn on at back of box
dreamup does not recognise the box is connected and still says "connecttion prepared - now switch on the dreambox"
all very strange, though its done this a few time then it just works for no apparent reason, i'l just keep trying...
homerjay
Chorley, Lancs
right, back into hyperterminal now, its just VERY slow...
it seems my boot was set the ethernet not flash which must of been slowing down the boot process.
just changed it back to flash now and saving
pant
3. load dreamup
4. click connect
5. connect power
Homerjay your bootloader is not corrupt for sure so that is good.Give a try to the link I gave you.It is 3 pages with questions and answers.I am sure you will make it.
homerjay
Chorley, Lancs
i checked that link, and by the end nobody provides a solution unfortunalty...
heres my hyperterminal when i coonnect now
Dreambox DM5620
loaded at: 00500000 005B31F8
relocated to: 00400000 004B31F8
board data at: 004B0128 004B0168
relocated to: 00404C14 00404C54
zimage at: 00405150 004AF237
avail ram: 004B4000 02000000
Linux/PPC load: console=null root=/dev/mtdblock0 rootfstype=cramfs ro
Uncompressing Linux...done.
Now booting the kernel
Welcome to the enigma serial access.
you may start a HTTP session now if you send a "break ".
HTTP/1.0 200 OK
Connection: close
Content-Type: text/plain
[ENIGMA] ok, beginning mainloop
+ (54) wizard: tv system
[FONT] creating new font color cache entry ff000000 .. 00ffffff
[FONT] creating new font color cache entry 33294a6b .. 00ffffff
[DHCPC] info, udhcpc (v0.9.9-pre) started
debug, Sending discover...
[FONT] creating new font color cache entry 225b7395 .. 00ffffff
[DHCPC] debug, Sending select for 10.0.0.6...
[DHCPC] info, Lease of 10.0.0.6 obtained, lease time 86400
[DHCPC] SIOCDELRT: No such process
[eDVB] restart Samba
waited for child 63
poll made error
homerjay
Chorley, Lancs
Halleluja Praise All Of You!
Its Only ****in Working!!!
Dunno How! But It Is!
I Feel A Little Dance Coming Along :D
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
Now all you have to do is load another image that will do what you want, now you know what was wrong it should easy (it never is!)
Well done - another one we didn't lose...
homerjay
Chorley, Lancs
CATCH UP GAMEBOY!!!
right lets see how quickly i can kill it again!!!
homerjay
Chorley, Lancs
thanks pant and gameboy couldnt of done it without ya's
:D :D :D
homerjay
Chorley, Lancs
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
homerjay said:
2 images on thereive never heard of, Quest Duo 5620 & Quest Jupiter 5620
Never heard of them - can you get Hydra Zeus for the 5620?
That's one of the better ones.
I'll have a look...
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
homerjay
Chorley, Lancs
hydra i had origionally and i couldnt get my motor to work automatically.
so i was hoping to have more luck with another image
BGonaSTICK
Brighton
Use whatever T_G's using. He's beta-tested them all, and runs a motor OK. :)
Check his posts here.
homerjay
Chorley, Lancs
reet, im gonna put hydra back on and the latest cpanel...
BGonaSTICK
Brighton
Think that Hydra may give you motor problems. It seems to be about 50-50 with users here.
homerjay
Chorley, Lancs
its terrible now, worse than the 1st time i tried...
now it struggles to move the dish at all...
very jerky and like the signal isnt getting through properly, i cant even program the sats manually like this...
tried on my bigsat and the motor moves fine...
BGonaSTICK
Brighton
Told you. :D
T_G had Terminator V9 working nicely with the motor, but is using something else now. Search his posts.
djc
DM7020-S
88cm Triax Dish
1.8m Channel Master soon to be installed
Doncaster
