Another Sky card in dreambox question
whatsthis
Likes
DM7020 Screambox
MAC OSX & windowzz 98SE
Gemini
1664 on tap
13°E
#1
Hi
Another question on using the FTA sky card in the dreambox.
I was using the sky FTA card in a sly box until it broke. So then I put it in the DB 7020 with no problems to watch ch4 & 5 but now ch4 has gone.
I've never had to edit the config file with the boxid but now I think I have to. So, how do I find out the boxID 10 digit number without a sly box ?
Likes
1,279
#2
How long since it's been in the original box?
whatsthis
Likes
DM7020 Screambox
Gemini
1664 on tap
13°E
#3
About 5 months. I'm using the 602 betad cam if thats of any help.
Did a rescan of the transponder but no joy, CH5 is still ok, just lost CH4
misses wasn't happy having to miss desperate housewives I can tell you.
john_graydon
Likes
Dublin....Ireland
#4
You can make up any box id no for it to work with ftv ch only.
whatsthis
Likes
DM7020 Screambox
Gemini
1664 on tap
13°E
#5
Good question - I shall try it tonight.
Entered a 10 digit boxid number and used the other setting found in the idiots guide but no joy. CH5 still ok.
Also tried loading emu and config again and also tried newcs.
Likes
1M dish
Valencia, Spain
#6
I don't think it has anything to do with box id. Are you in the UK actually? If not maybe your Astra 2 north beam signal is just not strong enough for channel 4.
And by the way, with mgcamd I can see all the channels I subscribe to, including the movie and sports channels without having to edit any files or enter the box id.
whatsthis
Likes
DM7020 Screambox
Gemini
1664 on tap
13°E
#7
Thanks zamolxes but it was a problem with the FTV card being out of the slybox for a few months. After an overnight stay in the box its back on now.
Butterbox
Likes
Dreambox 7000s serving 4 500s. 2 fixed dishes + 1 motor.
Dragon 4.1
Mayo, Ireland
#8
I have never had my card out of the dreambox for a year with no problems.
It might be worth entering the boxid of the digibox you left it in any way.
Also in the config make sure:
EMM-G = yes
EMM-S = yes
EMM-U = yes
If using Newcs then
Block SA ,UA and GA should all be "NO"
