Anyone got S*Y box with motor
gerryl
before I go playin 'again' was wondering if a S*Y STB was on loop through from Main STB (or straight through splitter!) and the motor parked at 28 would this work!...any done it :confused
satelliteman
A Sl<y receiver will operate through a loop out of your motor receiver if on 28e yes :D
But if you keep it connected, it will probably cause problems with your other receiver, as it powers the LNb even in standby.
gerryl
Will give it a go and if its playin up plan 'B' is a splitter...ta ta
You would get the same with a splitter, a twin or quad LNB is by far the most workable option.
gerryl
...good point never thought of that...so that's the plan...dual feed LNB sorted, many thanks :)
satelliteman
or A/B switch ???
gerryl
satelliteman said:
or A/B switch ???
got one in the 'auld' parts box will dig it out, until the Lemon .2 DB High Gain Twin Output arrives...thanks for the help and advise, cheers to ye both
