Arabsat
fadshen
Does anyone know how big my dish should be to receive Arabsat? and where can I get a second hand dish.
I live in Milton Keynes.
Fady
Arabsat 3A is ok on an 80cm in the UK. The others you can forget with anything of a sensible size.
fadshen
Do you know where I can get a second hand 80 cm dish or even 1.2m
Fady
80cm dishes are ridiculously cheap new these days.
Satcure or Brymar are ok as suppliers
Milkybarkid
fadshen said:
Strange .. sombody mentioned that a 1.2 m dish might do!!!
Fady
I have a 1.25 cm and can only get certain channels on Arabsat. You'd probably need a dish the size of a double decker bus to get them all.
:p
