Are there any multi LNB clamps....
2cvbloke
Near Pontop Pike, Co. Durham
Lancelot said:
See post #69 in this thread. :-rofl2
L.:)
What about it???? :confused
Anyway, me busy working on (read: Playing with) my Nokia as I just got the remote for it today, all I need now is the NA2.0 software and I'll be happy!!! :D
Just need to figure out where to get a new channel/TP list as it's missing loads of channels off it's scan of Hispa.....
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
It's just the rather disturbing 'want' to get some piccies into the mag, thats all ;)
Nip over to Lyngsat and scan the missing transponder by hand. :)
L.:)
2cvbloke
L.:)
Well, I got stupidly over-excited when I had text messages read out on BBC Breakfast news and Radio1's Chris Moyles show, so imagine how I'd end up if my big dish appeared in Wotsat!!! :D
Anyway, I think I'll have to enter the TP's mnually on my Nokia for now, but as soon as I figure out how to I'll use my new Null-Modem serial cable to down & upload stuff to and from the box...... :D
Lancelot
Retired Mod
SS1.
South central
Yes mate - if you can find something to talk to the box with, then you will be well away.
L.:)
2cvbloke
L.:)
I have seen some software suitable for the 9800s, but I forgot where it was.... :-ohmy
The_Shepherd
Hi.
Yes, there are multi-LNB holders with more than 6 degree separation - I got one from Ebay for just under 20 quid. It was made in Germany, but shipped from the UK. It will let you fit up to FOUR lnb's !
You can find a similar one here:
Ebay item 320038892896
Similar to the Triax one, it says universal, how does it attach to a circular boom arm?
Ah OK, so how does it attach to a rectangular one, as the picture isn't clear.
The_Shepherd
It comes with a bracket to fix over the end of the square arm and you run a bolt (supplied) through the bracket, into the hole on the feedarm and then in to the other side of the bracket. It's probably ideally suited to the LH style of dish that has a screw hole at the end to support the LNB holder but drilling a small hole isn't that hard.
You then fix the assembly together by following the diagrams, so you don't need to speak foreign !
Pretty straightforward really.
2cvbloke
Looks odd, and wouldn't fit my dish, especially as I got a multi-LNB clamp exactly 1 year ago.... :-rofl2
