Art Sports Card with DB5620 ?
djc
Likes
DM7020-S
88cm Triax Dish
1.8m Channel Master soon to be installed
Doncaster
#1
Will I need an actual Cam or will the Softcam handle things ?
Also whats the quality like, thought I read somewhere that the quality was poor ?
Cheers
dasteelman
Likes
85cm transparent dish
85cm Penta Dish (motored)
Black Ultra LNB
VU+Solo
VU+Duo
technomate 9100 linux
Quali-TV (4:2:2)
Eaglebox
UK nds card
Tyne and Wear
#2
dont know about quality
but newcamd emu supports art card
djc
Likes
DM7020-S
88cm Triax Dish
Doncaster
#3
Cool, thnx.
djc
Likes
DM7020-S
88cm Triax Dish
Doncaster
#4
Got my official card, but all I get is can't be de-scrambled, using Newcamd 5.28. Any ideas?
Cheers
djc
Likes
DM7020-S
88cm Triax Dish
Doncaster
#6
Which side up does the card go in :confused
BGonaSTICK
Likes
Dreambox 7000, Skystar2
Brighton
#7
You need to be running the corresponding NewcamD cardserver and possibly have edited your cardserver config file. Read my NewcamD upgrade guide for more details.
STICK
djc
Likes
DM7020-S
88cm Triax Dish
Doncaster
#8
Could someone just check to see Iqraa TV is working (on same TP as the ART channels, 13e) as I am trying this, due to it being listed as FTA, but not getting a picture, so the problem with the signal qaulity of 58-59% may be the problem?
Cheers
BGonaSTICK
Likes
Brighton
#9
IQRAA - ARABESQUE - 13E 12015MHz 27.5Msps H working fine here - picture and sound. 50% sig on SS2, not that that means much. That's a very watchable signal for me. I can watch glitch free down to about 25%.
STICK
djc
Likes
DM7020-S
88cm Triax Dish
Doncaster
#10
Right, I think it is definatley accepting the card, cos although I still can't see a picture and get the message can't be descrambled (usually get this with the Softcam/Keys setup as well), if I leave it on say ART 1, I can hear a bit of audio and also the a little bit of the picture comes through (broke up of course).
Currently sitting at around 58-59% signal (think the DB must refuse to do anything under 65%), I can only hope that my LNB turns up and then that I can fit it ok and hope thats will solve the problem.
Really wanted to get it done for tomorrow evening.
Is there anything else I can try to get that little bit more signal through, like altering some settings in the tuning parameters?
Cheers
dasteelman
Likes
Black Ultra LNB
VU+Solo
VU+Duo
Quali-TV (4:2:2)
Eaglebox
UK nds card
Tyne and Wear
#11
first of all..the card goes in with chip down.
yes amte the signal is weaker on the art channels.
59% signal will not get it for me either, must be 65% before it is stable.
I am in newcastle using 60cm mesh dish, working fine
BGonaSTICK
Likes
Brighton
#12
Cheers
Yes, 65% seems to be the threshold on the DB. Only dish positioning will achieve any better result (other than your LNB upgrade, a bigger dish or maybe better cable with less joins etc.).
Be very interested to see what difference your Invacom makes. I wouldn't bank on it being enough but I guess you'll find out soon enough.
What did you want to watch tonight?
The match is on TPS Star with a stonking signal and top quality picture (but no English audio).
That's where I'll be at 20:00. :)
djc
Likes
DM7020-S
88cm Triax Dish
Doncaster
#13
Hey, it was the LNB, now pulling a stable 76%, no BER errors :D
My match is on ART Sport 1 ;)
BTW, in a state of desperation, I also ordered a new Triax 90cm Dish as well, do you think that it would be more beneficial to use this, to replace the current 80cm Unbranded one I have?
Cheers
BGonaSTICK
Likes
Brighton
#14
It'll almost certainly give you a bit, but nothing like the Invacom.
I'm really pleased for you, and I'm seriously impressed with your LNB upgrade figures.
The Invacom is a serious piece of kit and no mistake. :)
Stick
djc
Likes
DM7020-S
88cm Triax Dish
Doncaster
#15
Cheers m8 :)
Now all I need to do is decide which image to go forward with, really like the look of DBF Revo, but just can't manage to install both Newcad/Scam plus keys for each, which is a shame.
On the LNB front, found the further I seated it towards the dish, the better signal I got.
Now do I install my new dish myself :-HB or get the installer again?
Cheers
BGonaSTICK
Likes
Brighton
#16
I think you know what our answer to that is going to be... You just want to make me say it don't you?
djc
Likes
DM7020-S
88cm Triax Dish
Doncaster
#17
Am I correct in thinking, that to perform this operation would require me to purchase a Sat Meter?
Cheers
BGonaSTICK
Likes
Brighton
#18
No, but for a tenner or so you'd be well advised to get one IMHO.
If you're on a tight budget and don't anticipate using it more than a few times then you can get away with having an assistant and maybe a couple of mobile phones to relay on-screen signal readings from the DB's 'satfind' menu.
I thought I would only use my meter once, but it's paid for itself many times over.
