Astra 19.2 and Sky mini-dish
student
DM 7025+ 500GB, 85cm transparent dish on motor, 50Mbit line, Czech Link
East coast UK
I have 2 question regarding Sky mini-dish.
First, I want to ask if anyone here has experience with Sky zone1 mini-dish and Astra19.2, particularly in southeast. Is it workable?
Second, does anybody have a picture of zone1 and zone2 mini-dish next to each other? Could you post it please?
Yes a 43cm dish will be ok most of the time in the south east of the UK. You may lose weaker channels during bad weather- use a zone 2 60cm dish if possible
student
East coast UK
Thanks, that’s excellent. I am really trying not to use the bigger one, it’s a long story. Could I use different (better = 0.2) LNB to make the situation better or is the LNB somehow “matched” to the mini-dish?
You need a peg fitting lnb - & I dont think they do the low noise figure LNB's for Sky dishes. If you want one you are looking at a round 60cm dish.
If at all possible I'd strongly suggest a 60cm zone 2 dish. If its a case of it being too obvious just paint it the same colour as the wall its mounted on.
student
East coast UK
This may be damn question, but is 60cm the width or height? What is the other dimension of the zone2 dish? I have never seen the zone2 dish in person and I cannot imagine the visual difference. Is it noticeable looking at it?
Here is a zone 1 compared with a zone 2. :)
student
East coast UK
Thank you so much for that. I think if my wife and/or neighbours see the zone2, they will get hart attack. If I was to modify or make new arm for the zone1 dish to accept some high quality LNB, would that possibly work? Also I have read some other posts here about motorising sky dishes, it has been mentioned that the LNB needs to be doctored, what does that means?
Thank you for your help
Forget about changing the LNB, the one supplied is made for the dish, just make sure that you use a new one. Why are your neighbours so fussy about dishes, it is not unreasonable to have a 65cm dish, in fact you can now have a 1 metre dish under the new rules.
You could always try one of the Technisat 45cm dishes, they have matched LNBs and perform very well. http://www.sateuropa.co.uk/product_overview.asp?id=1023&catid=1&subcat=2
student
East coast UK
I live in an apartment, lease states no dishes and uptight neighbours = stressed out wife = problems with my toys.
From experience what would you recommend on performance/visual impact ratio as best solution? The zone2, the Technisat or transparent 60cm? The dish will most likely be on small motor.
If you are having problems with dish visibility, then shoving one on a motor is going to make it even more visible, as it will stick out a lot more. :)
Out of the three choices, the 60cm transparent dish would probably be the least visible, but the zone 2 would hide the motor. :)
student
East coast UK
Ok, I think its going to be the transparent dish them. Thanks for the help.
I don’t think there is much choice with the motor, otherwise I will have to use dish with 2-3LNB’s and that would have to be even bigger.
student
East coast UK
Sorry one more thing, would the 0.2 LNB be useful with the transparent dish?
Buy the best LNB you can afford, you wouldn't go too far wrong with an MTI blueline.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Same rule applies with a woman too O-Ha O-Ha :D
student
East coast UK
Would you say that’s the best money can buy?
LOL, stop mucking about with my pictures. :D :eek:
@ Student, it isn't the best money can buy, but you are not looking to go feed hunting, so it will be a good solution.
