Astra 28.2 and Hotbird 13.0
mattybee
90cm Fortec Star Dish on a Stab Motor supported on 24" T&K brackets, with a Fortec Star Sigma reciever, picking up 4w to 42e
Widnes, Cheshire
Hi
I will be moving into a new house in a few weeks and it has, what looks like a 65cm dish up (I assume it is pointing towards Astra 28.2), Can I pick up Hotbird 13.0 as well through this dish without using a motor?
Thanks in advance.
mattybee
The Hotties at 13E are pretty powerful so give it a go - you have nothing to lose apart from a couple of hours tinkering time.
You *may* find you dont have a great deal of rain fade margin, but go for it :)
mattybee
Widnes, Cheshire
Oh Cool, will certainly try that once I have moved in, I have seen on another website what looks like a dual LNB holder is that worht getting?
Mattybee
I rather doubt there are suitable lnb holders readily availble for sky dishes - you are probably going to have to bodge it......
satelliteman
Just to add....
13e and 28e might well be possible with a suitable multi-bracket on your existing dish assuming it's not a mini-dish due to LNb brackets and availability as AS has suggested. You may need to buy another suitable dish with multi-bracket.
I actually tried it with a Z1 dish and made a temp bracket/arm. It worked but was bodged.
If you do, align centre on 13e and set up offset LNb for 28e
A picture of the dish would answer your question
gerryl
have alook at the ...TechniSat Multytenne -45cms receives 4Sats- ASTRA 1, HOT BIRD, ASTRA 3 and ASTRA 2.
Don't know anyone who's tried these and they are costly so you call :confused
Rather on the small side for the OP's location in Cheshire :)
