astra 2a testing signal 4k 28.2e
If it does indeed appear on Astra 3A sometime, according to their factsheet it'll be on 12.402 (V or H) - that's TP no. 3.236.
strs65
Decoders: VU+ Uno, DR.HD F15
DVB cards: TBS6983, TBS 6925
Dish 1: Tecatel 1.10m
LNB1: Smart Oxid
Motor: Amiko DM3800
LNB2: Invacom QDF-031
Greece (Crete - Chania)
Ok, in that case there is a transmission on 12402,V,30000 DVB-S2/8PSK 5/6 (Astra 3B, no reception here of Astra 3A), with an encrypred pid (0x00FF) with huge bit rate (~50Mbps), but without any video or audio pids. Maybe they are using some other type of proprietary format...
Channel Name:Service 2
Channel Data:12441 V,sr.29500,3/4
Typ:MPEG-4 FTA{3840x2160 Resolution}
Sat Name:Astra 2B
Pos:28.2 E
strs65
LNB1: Smart Oxid
Motor: Amiko DM3800
Yes, that's known, the one that started this topic, no problem with that. Here it works best with SmartDVB 0.2.5.1 and the Coreavc 3.0.1 decoder. Do you have any interruptions and buffer overflows with DVBViewer Pro?
With DVBViewer Pro image is smooth, uninterrupted,without any sound that has no audio-pid.Image goes well with DivX H.264.
In a word work very well with DVB Viewer!
strs65
LNB1: Smart Oxid
Motor: Amiko DM3800
Ok thanks! What's the setup of your PC? I'm having those buffer overflows here with DVBViewer Pro, but not with SmartDVB or AltDVB...
Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz,Physical Memory:8192 MB,Type: DDR 3,HDD:SSD Corsair,Graphic Card:NVIDIA GeForce GTX 460,OS:Windows 7 Ultimate 64 bit
what encrypted system using ultra hd
or maybe not use pid video or audio yet
strs65
LNB1: Smart Oxid
Motor: Amiko DM3800
This information is not given (no video/audio pids either)...
it can be not start pid video and audio
Astra 3B, 12363V 30000 2/3 8PSK ACM/VCM, MIS 17, also has some challenging video stream.
Broken video can be seen with VLC.
picture sony screen ultra ha from ibc amsterdam
BlindFaith
TBS 5925
What do you expect? According to crazyscan it's not a transport stream.
Right, forgot to check the stream type. In other words, if stream type is not a transport stream, "we" will never get a clear picture?
