Astra 2F: Pre-Operational Discussion
tothbros
Budapest, Hungary
The easy channels are the ones higher than 11200 MHz, mostly subscription or rubbish.
And BTW, before this switch 11023H was a lot stronger than the band D transponders, so if they go down by the same amount bigger dishes will be needed.
i think this depends on the location. here, in the eastern edge of the beam, where i am, the threshold is lower in the 10.7-10.95 range, anything higher is much harder to receive.
and also, 11023H was the weakest tp here by a mile, even before the move to 2F.
tothbros
Budapest, Hungary
DVB-S2 8PSK 2/3 = 6.6dB threshold (test signal)
DVB-S QPSK 5/6 = 6.5dB threshold (FTA SD channels, BBC2 England, for example)
DVB-S2 QPSK 8/9 = 6.2dB threshold (ITV HD)
thats different for me...for example:
10847V bbc hd, DVB-S2, 23000, 2/3, 8PSK - best reception, 24 hours a day, even in light rain.
10936V, itv hd, DVB-S2, 23000, 8/9, QPSK - worse than bbc hd, i lose it in bad weather
10994H, channel 5, DVB-S, 22000, 5/6, - worst out of the 3, pixelation at night, often lose it completely
Retired Mod
www.timo.me.uk
But you also have to factor in local variations in signal levels too. Each transponder may be received at a slightly different power level.
vladan10
bigger dish that you can think .
pc card
Southern Europe,Crete
jast now have lost 1db here on 11023 H
from 8.5db yesterday
7.5db :(
5m dish
William Kay
Near Bergen, Norway
Humax Foxsat HDR
80cm Finlux dish
Inverto LNB
Bergen, Norway
11023H coming in right now (1631 CET) at 80% strength/50% quality. Have never seen 2F outside the 1140am-1230pm time-window previously. 50% is borderline quality, but it's stable at the moment.
vladan10
pc card
check tomorow morning if it up again signal
hi m8
morning after 9 yes , but tonight 19.00 GMT is the best time to check .
i hink signal can down 1db to 1.5db
betwin morning to evening
i have problem signal also astra 2a 11798h when it down signal at morning 8.2db at 6 db at evening
it close the limit signal
My comments were based on the modulation of the carrier and the SNR needed, nothing to do with the signal level in any particular location.
joddle
Massanassa, Valencia, Spain
Well this is so exciting - but I really fear there may be something wrong as there have been no more test transmissions other then on 11023 - I suppose we will know after first week in Dec as people are claiming the move will be by then. Everone is speculating but none of us know anything for sure and its all a bit frustrating - lke wating for Christmas as a kid. At least we now have from this and other sites a good idea of where the sat will be receivable and on that basis some people are already buying new dises - a bit early in my opinion as we really need to see the final picture once she properly lights up which may give a slightly different reaults to those we are seeing now.
radioagogo
channelmaster 2.4 offset dish Invacom twin C120 feed Panasonic TUSD 45
openbox S16, X5. technomate TM5402 HD M2
Villaverde Fuerteventura
TENERIFE-TV said:
MULTI TV GHANA now on ASTRA 2F WEST AFRICA BEAM
but with different symbol rate
FREQUENCY<span style="background-color:rgb(254,254,254);"> (12522) and new
SYMBOL RATE (19531)</span>
Hi All, is there anything being transmitted on this transponder form WAB? cos if there is I aint getting anything other than the Eurobird channels here in Villaverde. Also getting a pulsing signal on 11023, it's cyclical (is that a word?) I'm guessing it's airport radar in Arrecife, line of sight just across the water from here.
Mr Hoover
Various Receivers and Dishes
Portugal
joddle said:
Well this is so exciting like wating for Christmas as a kid.
Hmmm...Maybe more like in the waiting room at the dentist not knowing if the tooth needs
pulling out !!
No Change here in SW Portugal overnight that I've seen.
FRINGE
Adeje in Tenerife
laminas 2.7 offset
laminas feed horn
Invacom quad LNB
Humax foxsat PVR
Tenerife
11023 steady here (constant signal) so must be some form of external interference.
Mr Hoover
Portugal
Do you have access (beg borrow steal) to a signal/spectrum analyser to
"see what's going on" on 11023 ?.
FRINGE
Adeje in Tenerife
laminas 2.7 offset
laminas feed horn
Invacom quad LNB
Humax foxsat PVR
Tenerife
I have a 'Marco Polo' (guess that name sums it up pretty well :) ) sat meter (SM-05) that I bought some time ago. Not sure what I can do with this as I'm no techie and got it solely to help me align my dish - it beeps !!!.
TENERIFEFORUMTV
Persona non grata
1m
TENERIFE (Spain)
have you got a watchable BBC HD picture on 11.023 ??
TENERIFEFORUMTV
Persona non grata
1m
TENERIFE (Spain)
i think that the signal from E28A on 12.522 is much to powerful on the islands to let 12.522 from 2F WAB to get a look in
the fear is if they uses the´d´ frequency's for UK and WAB at same time as WAB is closer ....
Mr Hoover
Portugal
No,unfortunately that won't help
Seeing the Spectrum live on a screen of 11023 would take a lot of the guesswork out as to
what's actually happening with the signal in your part of the world.
joddle
The ideal solution - send 2F off to 19.2 to use its very narow beam on the Canaries (ideal!) and leave 1n at 28.2E (perfect!).
FRINGE
Adeje in Tenerife
laminas 2.7 offset
laminas feed horn
Invacom quad LNB
Humax foxsat PVR
Tenerife
No. Never have. Just the signal 80%S 60%Q on the Humax manual search screen. The search function repeatedly say's "no channels found" (as per my earlier post/photo in previous thread).
If anyone has an analyser and wants to come here, they are more than welcome.
