Astra and Hotbirds Info..
M
morgan
pj::
Hi all,
I'm new to this and need a bit of help please. I have just had 2 satellites fitted at my house Astra (Sky Digital) and Hotbirds. I access both satellites via a standard Amstrad DRX100 Sky digital Box. For hotbirds I add the channels using the frequencies in the add channels section. To switch from 1 LNB to another I have a manual A/B switch which means I have to get up all the time to switch satellites. Does anyone know a way that this can be done via the remote control??
Also some of the channels I used to watch ARY Digital for example which is an Asian channel that shows alot of cricket (I'm a cricket fan!!) used to be free but it has now been encrypted using Irdeto2 according to lyngsat. Is there anyway to get this channel now through hotbirds for free??
Thanks for your help
lee32uk
lee32uk
Technomate 1500ci+ super
Triax 1.1m dish
Diseqc motor
Invacom lnb
Manchester
Hi
Satcure sell an LNB switch and Adaptor which lets you switch between the 2 LNB's with your sky remote.
http://www.satcure.com/tech/cs012.htm
