Batch conversion of images?
Likes
relook 400s with 1 meter wingard dish/invacom qph-031 lnb/sm3d12 motor(tuner1)
2 dish 500 with disecq for tuner 2
twinhan 1020a pci card in a 2600+ mobile athlon clocked to 3300 mghz.
dishnet 301 rec rom 10 to 103 conversion.
CANADA
#1
hi, ive been playing with slideshow in radio window, and have mplayer, a file to convert jpeg to mpeg, so the relook can use them, i have to resize my pics first, say i do 25 at a time, i resize all 25 to 720x880 then rename them all sequentially for easy c/p.
then i open a cmd window and goto mplayer directory and c/p this cmd line in:
mencoder.exe mf://relook1.jpg -o relook1.mpeg -ovc lavc -lavcopts vcodec=mpeg2video -of rawvideo
with relook1 being file name. so i just change name and c/p the line and bam, make the image. but doing this one at a time is slow.
is there a way to do say 20 or 50 at a time?
i tried this :
mencoder.exe mf://*.jpg -o *.mpeg -ovc lavc -lavcopts vcodec=mpeg2video -of rawvideo
using the * for filename, it almost seemed to have worked, it said in the dos window it rec 63 files for conversion, then never made it past the 1 one.failed to open file.
has anyone done this before and is it as easy as a cmd line? id like to make a couple 500 pictures for slideshow!
any help appreciated.!
