Wf100 & Wf125 have pvc sheath which isnotgood when it comes to water here is a test get a bowl of water cut a length of webro wf100 say 1m of it them cut a length of say televes pure copper core coper pair rg6 which has polyethylene sheath,
Then put both of them in a bowl of water but keep both the ends of the cables out of the water as this will mess the test up before you start then leave it for say two weeks you can tape the ends of the cable to the outside of the bowl to make sure no on knocks them in the water,
After two weeks time you take the cable out of the water and cut it in half you will fine the webro wf100 pvc sheath has let moisture in and the copper had corroded and if you do the same to the televes polyethylene sheath it will still be like new,
Also wf100 is rg6 its just a type of rg6 the same way as a ford fiesta 1.6 pertol and fiat punto 1.6 petrol are both a type of petrol car, Some basic aerial & satellite installers who have no qualifications in the telecommunications trade will tell you different as it makes them sound good,
There are alot of grades of rg6 from the cheap stuff the sell in b&q to the high end range from televes,
Also when i spoke to our webro rep in the past i asked why are they selling alot of wf100 for use outdoors use when it only has pvc sheath his reply was 90% of installers are dull enuf to buy it for outside use and we do not care as it brings the money in,
