Best dish for my roof
longstockings
Satellite Whore
Likes
Technomate 1500 CI+
80cm Polycarbnate Dish
0.3db Universal LNB
Moteck Digipower Motor
Totnes, Devon 50.4320N, 3.6690W
#1
I installed my motorised system only to find that my dish would not be able to receive hispasat from it's location on side of the house.
Option 1
Put dish in back garden
Problem
2 big Rotweillers would eat it
Option 2
Put the dish on the front of the house
Problem
Girlfriend would do a John Bobbit on me (ouch)
Option 3
Move the dish to the roof
My setup included a 80cm polycarbonate dish but I have noticed that it does suffer in rain / high winds quite badly. South West is real stormy lately
The reason I went for this dish is because I wanted the installation to be as discreet as possible and didn't want to get into trouble for having a dish larger than 90cm.
But my roof is high up and no one is going to want to go up a ladder and measure my dish to see if I am breaking the rules.
My Question
What is the best dish up to 1.2m diameter that I can get
best = great signal strength / little maintenance / good value / not too ugly
It will have to be suitable for a diseqc 1.2 rotor so dish weight may be a factor
Lancelot
Likes
SS1.
36v H to H 62E - 61.5W
South central
#2
Hello again :)
The Triax TD110 (capture area 100cm) has a lot of good feedback
and deservedly so.
However - the same company make a 1.2M version of this antenna
since the demise of Channel Master (hoping to fill the gap I suppose)
This is supposed to be VERY good.
But I don't think you will see it for a couple of months until the dealer
stockrooms are clear of TD110s.
I have enquired @ Triax to confirm the existence of this beast and
the guy E-mailed me back asking where I was so he could find a distributor
near me(I never replied).
If you can get away with it this is probably the thing to have
anyone feel free to jump in here now !
Let us Know what you decide and how the fix goes
Good Luck
L
Likes
1,287
#3
I wouldn't want to put a 1.2 metre dish on a roof mount, particularly if using a DiseqC motor, that sized dish would have an unacceptable wind loading. Where on the roof are you intending to mount it, pictures would be helpful.
PS. I do not know of a 1.2m dish wihich is not considered ugly, particulalry if it is stuck on the top of a house. ;)
longstockings
Satellite Whore
Likes
Technomate 1500 CI+
0.3db Universal LNB
#4
I'm at work at the moment but as soon as I get home I'll dig the camera out
Lancelot
Likes
SS1.
South central
#5
OK agree with the wind loading Rolf
But I've never seen an ugly 1.2mtr dish
One man's aesthetics is a another man's planning nightmare..:)
I'll shut up now :D
longstockings
Satellite Whore
Likes
Technomate 1500 CI+
0.3db Universal LNB
#6
My first attempt (old setup)
A blatent copy (sort of) of RolfW's setup. It seemed to work for him
Unfortunately will bang into the wall if I try to move to Hispasat 30W
The house is actually cream and I have bought some cream hammerite paint to spray the mounts as they are a little ugly but so much easier compared to the previous wall bracket.
So it has to go higher so that it will clear the roof and I'll need a longer pole
This will be the new position
So thats about it
This is my labour of love
Project started late July
Expected finish is before xmas
EDW
Likes
Dishes over 90cm require planning permission if attached to the fabric of the
property.
Get a muzzle for the dogs! There's no other way. Cable should be ducted and
buried deep to at least 450mm. Ducting is about 75p a linear mtr. Buried cables must
be marked up to warn contractors in the future, this includes low voltage. If you
really want to do it right, the correct colour for cable tv/fibre optic ducting is
green.
I am a world of trivia.
Likes
1,287
#8
I would be more inclined to put the dish lower down the roof, it doesn't need to be at the apex and in fact would contravene planning regs up there, it should not be higher than the tallest part of the roof, excluding the chimney.
gameboy
Ding Dang Doo
Likes
5
Scotland
#9
rolfw said:
I would be more inclined to put the dish lower down the roof.
Easier to get to on a ladder as well!
As your dish isn't that big I'd advise putting the pole brackets closer (depth wise) together.
A shorter pole should help you get the vertical quicker.
Can't see from the pics, are the f-connectors covered in waterproof tape?
Likes
Recently moved house and in the process of investigating new kit.
London, UK
#10
I am just about to install a dish at my new house and am interested in RolfW's drawing. Planning regulations state that the dish must not be higher than the highest point of the roof but in your drawing the dish itself is still above the roof.
I have the same problem as Longstockings. In my case the arrow in his picture, if you look at my house, is pointing South. My house is semi-detached so the only way to get a South facing dish is to point it over the roof. ie. If it is on the West side I cannot receive the far eastern satellites and vice versa.
Checking the sun at and just after the recent equinox there is a clear view from the apex of my house to all satellites from 70° East to 70° West. This would be wonderful, at my last house I could get only 60° East to 45° West.
Does this mean that the only way I can get what I would like is to obtain planning permission or, if I interpret your drawing correctly, can I get away with the mount below the rooftop but the dish peeping over?
I do not have a problem with the other two bugbears of planning regulations: the dish will not exceed 90cm and it will be the only one.
I could, of course, try the old trick of chatting up the neighbours but it would just be my luck that a member of the local planning department happens to walk past my house on an off day.
Likes
1,287
#11
Hi DavidW, the top of the dish must not be higher than the highest point of the roof, so as long as it is on the lower part of the slope, it can still be above, but not higher than the apex.
RedDevil_UK
Likes
34
Dreambox 7000S, VU+ Solo2, 1.1m Dish, Moteck SG-2100A DISEQC Motor
Rochdale
#12
original quote by Longstockings..
thats like saying if i had a Bentley Turbo i would hide it in a garage so it size didnt offend the neighbours.....
go on be a devil, be the man that doesnt give a sh#t :)
my dish is on top or the porch at the front of the house, some neighbours have commented on it, just curious really.
they are lucky, i wanted a 1.8m dish but the guy at the shop talked me out of it :(
Likes
London, UK
#13
I'm sorry Rolf, but my geometry isn't quite as good as it should be.
You say the top of the dish must not be higher than the apex of the roof. So, as I understand it, if I mount the dish on the east side of the roof I will not be able to see the further western satellites and vice versa: west side, eastern satellites. If I mount the dish on the end of the house, which, as I said, is North facing, it will have to extend somewhat to be able to point to all satellites. As the satellites around 0° longtitude are fairly high, (my latitude is 51°), the dish will be able to see over the apex. As long as the arc is visable as the roof slopes East and West all should be OK, even down to the 4° elevations which can be seen from the apex.
As I said, my geometry isn't too hot but I hope my presumptions are correct.
My question is, how far can I extend a 90cm dish from the North wall to be able to point South? Also, what sort of mounts would I need? Would I have to have a light mesh dish instead of a solid one? Perhaps the real question is, is it actually possible? Of course, I could have one dish on the West wall and one on the East but then we are back to the planning problem: two dishes! And the East wall is the front of the house.
Please don't suggest that my solution is to move house.
