D
djc53320661
Hi
Which card would be best for the above.
I have been looking at the Skystar 1 and Win DVB-S 1.3. Whats SCPC reception and so I realy need it as it says that the Win DVB-S does not support it ?
I am ideally looking for one with a loopthrough as I have a Skystar 2 in my other PC which I use for Eol (soon to be Netsystem) and would like to be able to connect both without having to pull cable in and out of each machine every time I want to do use a different service. Or is there some sort of special Sat equipment where I could split the feed, so I could get one with a single lnb input ?
At the moment I have a Skystar Zone 2 dish and really want to try and setup with Astra (which I'm on at the mo) and Hotbird. Would I be able to buy a Monolock to fit due to the different arm ? I found one web site with the MTI Monoblock and it says it will fit any dish ? Or do I need new equipment
Any other suggestions would be greatly appreciated as I'm getting myself confused looking at all the differnt configurations and options.
Also I am based in Yorkshire, UK
Again any help would be great
Chris
Chris
