best lnb for Asc signal (andrew) 1.80 mt
otokoc
DM920HD
prodelin1244
Balikesir,Turkey
does anyone have any ideas on the best lnb to use on a Asc signal (andrew) 1.80mt to receive BskyB 28.2 E ? thanks in advance
Which channels are you particularly after? Quite a few will be out of range for you in Izmir.
otokoc
DM920HD
prodelin1244
Balikesir,Turkey
Now I can watch I already ASTRA2A/2B but i havent signal 12266 H,12344 H,12363 V and astra1N
Well you can forget anything on Astra 1N - thats well out of range for you.
12266H,12344H,12363V are all HD frequencies and not available on a standard DB500. If you want them you will have to replace the receiver.
wod
yorkshire
To get the best out of the dish you will need a c120 lnb to bolt to the feed.
The recommend is invacom as I don't think inverto make a c120 black ultra version yet.
otokoc
DM920HD
prodelin1244
Balikesir,Turkey
I already can watch famaval135 antenna. Today in feedhorn cm180 + buy, I hope you use the antenna as soon as possible.
Even so you wont be able to get Astra 1N or the HD channels on an SD receiver.
Shouldn't 500HD be able to get these?
otokoc
DM920HD
prodelin1244
Balikesir,Turkey
yes.i have dreambox 500 HD
Didnt your profile say DM500 (no HD) until a few minutes ago?
I know I double checked.
otokoc
DM920HD
prodelin1244
Balikesir,Turkey
people saying Found that on a 1.8m and 2.4m ChannelMaster, the feedhorn and Invacom produced better results than the Black ultra.
Can anyone say its true?
Seems it's true for 1.8m and 2.4m dishes. On 1.2M Channel Master though, the Black Ultra seems better.
otokoc
DM920HD
prodelin1244
Balikesir,Turkey
brigado captain jack! :-applause
otokoc
DM920HD
prodelin1244
Balikesir,Turkey
my test result cm180 with invacom and inverto
otokoc
DM920HD
prodelin1244
Balikesir,Turkey
otokoc
DM920HD
prodelin1244
Balikesir,Turkey
