Best LNB for Triax TD110 dish with folding arm!
H
Haroldinio
Foreign Channels
Hellas Sat 2
Hello,
I am having some trouble with a week channel with polartity V on my Sat system.
I use a Titanium .1 lnb
Triax TD110 folding arm dish
Technomate TM-5400 CI+
alligned to Hellas Sat @ 39degress.
The channel in question is PIK with the following parameters
11146 V
S/R 3333-3/4
I have read some posts about tweaking the arm and lnb .. I have tried scewing the lnb to maximum affect but on a bad day the results are not good.
Can anyone advise on this? Is there a means to find the optimum focal point and find tune?
Harry
That channel is causing a lot of problems, some receivers simply don't like the Symbol Rate of 3333, a TD110 should easily pull in enough signal, but you could try skewing the LNB slightly more, about 20 to the hour from behind the LNB towards the dish.
H
Haroldinio
Foreign Channels
Hellas Sat 2
Hi thankyou..
What you mean by towards the dish?
Robbo
Robbo
Retired Mod
Gravesend,Kent,UK
Haroldinio said:
Hi thankyou..
:-rofl2
That is where you are standing while adjusting the skew
satelliteman
satelliteman
East Midlands, UK & Lanzarote, Canary Islands
Slight mis-alignment was also the cause of two I recently came across where Riksat wasn't being received.
H
Haroldinio
Foreign Channels
Hellas Sat 2
misalignment of the dish?
satelliteman
satelliteman
Not quite aligned to the satellite. In your case it's probably ok but something to consider.
