Best Motor for Gibertini 1.25m dish
tigertimtim
Likes
1500 Technomate, 1m Gibertini dish, Smart 0.2 Titanium lnb
Hull
#1
Hello,
Iam upgrading the size of my dish to a 1.25 Gibertini, ive been told i would need i different motor than the one iam already using for my 1 m dish, can anyone please recommend which motor i should go for and where to buy from (pm please)
thank you
Tim
Lancelot
Likes
SS1.
36v H to H 62E - 61.5W
South central
#2
Probably not a diseqc one I would say.
Got one of these plates, and they are a very good sail when it's windy.
Something in the 36V catagory is what you need, either H-H or polar mount and jack.
L.:)
tigertimtim
Likes
Hull
#3
is a Stab HH 120 motor ok for a 1.25 dish ?
Lancelot
Likes
SS1.
South central
#4
It will turn it OK for a while, but you have to think of that small plastic drive train trying not to strip itself when the wind is trying otherwise. I would always err on the side of caution, especially if the dish is going on the wall or the roof.
L.:)
Likvid
Likes
5
Stockholm, Sweden
#5
Moteck SG2100A is no problem on the Gibertini 125cm dish.
Several DXers in Germany run with this combination with no problems.
jakenl
Likes
Manhattan Starlight 5900+PVR-80GB,Topfield TF5000CI,Skystar2,110cm dish, Invacom 0,3dB, Moteck SG2100A,range: 75East-61West,AMD Sempron 2600+, Windows XP Pro.
The Netherlands
#6
Is there anyone who has a picture of a Gibertini-Moteck combination.
Someone I know has recently replaced his Triax for a Gibertini 125.
He says that this dish doesn't fit on the Moteck and had to replace the motor for a Stab HH-120, which is much slower.
Perhaps a picture can clear up some things.
Jakenl
Likes
1,279
#7
Despite what people are "getting away with", I really do not recommend the Moteck, or in fact any other DiseqC motor for driving a 1.25m dish, regardless of how light it is, unless it is in a very well sheltered location.
Pretty much without exception, the DiseqC motors which I have seen driving a dish bigger than 90cm, have had excessive backlash (play) in the arm and although this can be adjusted, there are a finite amount of times you can do it.
BGonaSTICK
Likes
Dreambox 7000, Skystar2
Brighton
#8
I like this image from satellite superstore.
I'm sure they won't mind me using it to get the point across.
OK, it's a bit extreme, but you get the idea.
Likes
1,279
#9
I must confess that the Jaeger SM-1224 is a lovely piece of kit, shame I haven't got the room for a bigger dish. :)
BGonaSTICK
Likes
Brighton
#10
Yes, my dream combo right there in that wee picture...
I think I'll have to change wives before I change dishes though. And credit card companies.
Likvid
Likes
5
Stockholm, Sweden
#11
Jakenl
Here:
Gibertini 125cm/SG2100A Moteck.
Lancelot
Likes
SS1.
South central
#12
If he didn't have a sunken windless garden then he might struggle .
Still dodgy though
L.:)
Likvid
Likes
5
Stockholm, Sweden
#13
Here are some more working setups, this one with a STAB motor.
johnsattuk
Likes
2
Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide
West Mids, UK
#14
I'm sure it would take a small dish :D
I quite like that motor, I have been wondering if it would be possible to modify one to diseqC control but with a separate 36v supply
Likes
1,279
#15
Just use a Vbox, does exactly that. :)
PS. Don't think I've even got room for the motor. :D
Likvid
Likes
5
Stockholm, Sweden
#16
The quality on the Jaeger isn't that good as some beleive, there are reported problems of the metal cracking during higher winds, look at the pic below, i guess it's the famous weak Chinese metal again that is spooking.
johnsattuk
Likes
2
West Mids, UK
#17
I have looked at the Vbox, but it's yet one more box and cables in my stack, as far as I know, does not have 'usals' or 'goto 0' which I really like.
I am suprised that somebody isn't making a high power motor with builtin diseqC. I think that I shall be canabilising an SG2100a to experiment with.
Anybody got one with burnt out motor or stripped shaft or cracked case, I only want the electronics. :D
I have been looking for info on the diseqC commands that the receivers send out, I need to know the movement per pulse. I think it is 0.1deg but have not found out definitively yet. :(
Likes
1,279
#18
What sized dish was it driving?
johnsattuk
Likes
2
West Mids, UK
#20
Is there room inside the motor case for a small PCB, do you have any pics of the rest of the motor. :D:D
