blademedia
- Jul 29, 2016
- Sky
- UK
I had a call out to one of those this morning. My initial thought was that it was just a cheap box, but after about 30 minutes I was hating it with a passion. The client was more angry than me after I showed him that the outdoor equipment was working perfectly well with his seven year old Venture HD box that he had replaced since he thought it was obsolete.
Attached to a Dark Motor, this V7 thing wouldn't drive to the correct position, either in GOTOX mode or DiSEqC 1.2. When it is on a satellite it takes forever to tune into the channels.
Firmware is currently V3.02.102.510 (dated March 2017) no satellite position I could find would allow it to upgrade to a functioning , friendly receiver.
This is the version with single USB btw, not a clone.
Hi channel hoooper, thank you for the information, the best firmware to use is V2.24.100.404 22/11/16 DiSEqC 1.2 works perfect but GOTOX is a waste of time,
As for scanning you need to use blind scan not full scan full scan scans every transponder it has in its data base,
Its not really a box for a novice to play with, it takes some getting used to, perseverance is the key here .
