big PFA dish,using for wland,where i can find 2,4 ghz LNBS?
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
Hello!
i want to use,my 2,20 m Tagra dish,like a big wlan antena reflector,with this size,i the gainwinning in wlan,would be real high aproximently 40 DB!
in reveiving and sending direction,maybe i range,of 7 km or more,i can imange,my only problem,i know that this lnbs exisits,but i dont find any shop where i can buy one?
anyone,have make this tests allready,and can tell more?
caveman
comag sl65/12 b1 x2 skystar2,1.1mtr ovel thing with 13,19,23,28,80cm lidl dish 35cm porty dish maplin square dish on the shed.all with sharp white lmbs.tandy scanner on a discone for metosat and wxsat.
sw uk
you can make your own "lmb" useing a cantenna or a 12db yagi at the focal point of the dish..but you will need the ap or client near the dish..2.4ghz and coax dont really work to well with out huge losses..
also take a look here _http://people.wallawalla.edu/~Rob.Frohne/Airport/Primestar/Primestar.html
