Blindscan And 4.2.2 Receiver
Alan Pee
Can anyone who knows well plse recommend for me a good receiver that can decode 4.2.2 transmission and can also carry out blind scan function. I know the fortecsatr 5100 ultra does blind scan but I am not sure if it can decode 4.2.2 transmissions. I presently use an interstar and it can't decode transmissions in 4.2.2. Plse help thanks,
Don't know of a domestic STB that does both, but the Quali TV QS 1080R can apparently resolve 4:2:2 transmissions as well as being HDTV ready, although at £500 a throw it would be a lot cheaper to get a satellite PC card for the 4:2:2 stuff and the Fortec for blind scanning.
Alan Pee
Thanks for your answer and advise. What sat. PC card would you recommend then Llew.
Most people here are more than happy with the SKystar2. Cheap'n'cheerful, does most of what you require.
Check the PC Card section on this forum.
S
sprattgraham
The Quali-TV QS-1080R Can Resolve 4:2:2 Transmissions With No Problems.
You Can Scan FTA Or Scrambled Channel From A Pre Programmed Frequency List That You Can Edit.
It Also Support's Diseqc 1.0 & 1.2.
If You Get The QS-1080IRCI You Have A 1 CAM Slot.
Chepest Place To Get The QS-1080IR Is From This Company In Spain.
ANTNET Digital S.L.
www.antnetdigital.com
Tel: +34 91 81 633 80
Cost Me £400.00 Including The Euro1080 Viewing Card.
So Not Include The View Card It Should Cost Around £300.00
Lancelot
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
You can set ProgDvb to blindscan an SS1/2 by writing your own transponder info for it, or the newer Technotrend drivers have a good scan function in them.:)
L.
Skybox F3
Tandberg Alteia are supposed to be good receivers, althoug being professional rx's are NOT cheap. They turn up on ebay occasionally.
S
sprattgraham
If Anyone Is Interested I Am Selling My Quali-TV QS-1080IR HDTV Satellite Receiver On Ebay.​
The Quali-TV QS-1080R Can Resolve Mpeg 2 4:2:2 Transmissions.​
Lancelot
Lancelot
Retired Mod
SS1.
South central
sprattgraham......
Could you put this in the 'For Sale' section as that is the correct place +
You will probably pick up some interest !
Cheers :)
L.
S
sparky208
hi i have a quali hd just wanted to no can i put a dragon cam in it and is there a hack for euro 1080 i got it second hand with no card in it dont fancy paying 170 quid for a card:-doh!
W
wod
yorkshire
