boomerang without sound?
M
murtaza
Likes
Currently the above channel (hotbird 3, TPS suite) is clear with my DC 3.01 but without sound? I believe the probelm is realted to DC as the channel is fine (clear with sound) with my Matrix Reloded!
Any help to resolve this would be appreciated.
Cheers,
MM
M
mumtazrizvi
Likes
Pakistan
#2
Cheers,
MM
Hi Dear Murtaza
Good Afternoon
I think it depends upon STB too because I do not
have any problem with Boomerang, the sound is
quite OK.
Regards
Mumtaz Rizvi :)
M
murtaza
Likes
mumtazrizvi said:
Hi Dear Murtaza
Good Afternoon
quite OK.
Regards
Mumtaz Rizvi :)
Thanks for your response Mumtaz, if the STB is to blame then why the same channel is fine (sound & picture) when i insert Matrix reloaded CAM in my STB (Topfield 5000)? I feel its somehting to do with DC or the version i'm running, can you tell me what setup you are using? this might help to eliminate somehting!
M
mumtazrizvi
Likes
Pakistan
#4
Hi Dear Murtaza
Good Evening
I am using Humax 5400 IRCI with Matrix Reloaded latest version
but sometime I am using Starsat (2 embeded universal and 2CIs).
I don't mean the STB has to be blamed, that was my personal
opinion. I agree with you it might be a DC problem. Uptill now you
hav'nt disclosed that in which Receiver you are facing problem.
Regards
Mumtaz Rizvi
M
murtaza
Likes
mumtazrizvi said:
Hi Dear Murtaza
Good Evening
Regards
Mumtaz Rizvi
Dear Mumtaz
Thanks for your help, I use Topfiled 5000 PVR, i have MR but recently bought a DC 3.01 (i think firecrypt). I am still baffled to know why the channel is fine with MR but not with DC, my guess is that i might have to update my DC to ??. I hope someone out there can confirm this!
M
mumtazrizvi
Likes
Pakistan
#6
Hi Dear Murtaza
Good Afternoon
I think DC is better than MR because of its supporting team.
You can watch S2 with the Dragon, have you purchased DC
with the loader card? and/or Fun-7 to upgrade if no purchased
it and load the latest 3.04. Regarding fine/non-fine it depends
upon STB.
Good luck!
Regards
Mumtaz Rizvi :)
M
murtaza
Likes
mumtazrizvi said:
Hi Dear Murtaza
Good Afternoon
upon STB.
Good luck!
Regards
Mumtaz Rizvi :)
Hi Mumtaza
yep i agree that you can watch s2 with Dragon but unfortunately i cannot search for some Italian channels (sky etc) on HB3, my STB just refuses to search for those channels, despite enetering all the attributes manually (i.e pids etc). Oh yes i bought the DC with CAs2 deluxe so programming the DC would not be an issue, currently my DC is 3.01 but your post suggested that a patch is already out there (3.04), not sure what has been fixed in 3.04? Can you tell? BTW my boomerang problem has been resolved by itself, one-day sound just returned and it made the kids a whole lot happier J.
Slightly off subject, I gathered that in Pakistan there is this thing called ‘cable’ exists, I do not know ins and outs of this but curious to know how does this network works? i.e what hardware/software these guys use to distribute channels over a network which can span for thousands of houses?
Let me know if you have any info on the subject.
Regards
Murtaza
