Bush HD Freesat box problem
perryowens
Bush HD Freesat box feeding Sharp HD LCD TV
Surrey,UK
I am new to this Forum so apologies if this has been brought up before. I bought a Bush HD Freesat box and connected it to a sky dish. Signal strength averaged 78%. When using an HDMI cable connection to the TV I found that after switching the box to standby and back again, or even after just leaving it on overnight, I got a blank screen, with sound only. I exchanged the box at Argos but the replacement does the same thing. I then called the Bush helpline. They told me to turn off the power, pull all the connections then replace them and switch on. That worked but it's not what I would call a permanent fix. Am I doing something wrong or should I get my money back and buy a Humax box?
perryowens
cjgall
Topfield 4000PVR with Aston 1.07 CAM, (canaldigitaal), dragoncam,
Sky digibox,
Bush HD Freesat,
Visiosat trisat looking at Astra1, Astra2 and Hotbird.
Netherlands & Central Brittany
If you have set the HDMI output to 1080i then you could try setting it to 720p, this worked for me. As for the humax box, I would check to see if the lip-sync issue has been fixed first.
bigtone
Dream 7000
2xEurovox red
Humax HD
No the lip sync issue is still outstanding.
Got this reply yesterday 14/7/08
Thank you for your email
There are a small number of our customers experiencing an issue with certain TVs
We are aware of this issue and we are working on a solution for this
There will be another OTA update in the coming weeks
Please visit our website for scheduled release dates
Best regards
Humax freesat Support
Tel: 0844 669 8800
