Cam for recieving sky3 channel4 and five
C
clubsms
Likes
19
Canaldigital CDC-7000 st
Finland
#1
Hello.
I know nothing about cams but I want to learn.
I am soon recieving a sky box and a freesat card.
I would like to view sky3 channel4 and five on my current reciever that has a ci slot.
What cam should I buy? Dragon, t-rex, t-rex super diablo cam or another cam.
Currently I am only intrested in recieving the Freesat channels BUT I might be intrested in the other things the modules also can do.
Please help me. Can any of the modules above decode the freesat channels without programming them?
What cam should I buy? I am on a limited budjet, is there anything else I need to buy?
PLEASE HELP ME!
Turok
Turok
Likes
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
#2
,hello the dragon cam,should supportet nds
also some reveivers like the openbox,the problem is autoupdate of the card afer 6 weeks,does not work,on any cam,and the card must be back,into the orginal reveiver !
Likes
8,642
Skybox F3
You are out of date Turok. At least 2 dreambox cams now allow the card authorisation updates through. CCCams certainly do.
Turok
Turok
Likes
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
#4
realy ,dont have dreambox only dbox 2?
what cam should i buy?
works the upgrade,also over the normal sky box?
iam looking for a sky hd subsribson,but iam not sure,if key change,can i upgrade the card in normal sky dvb box what i have from thomson,then put it back,in the nds cam and upgrade works also for hd channels or not?
after sky will replacing the cards,no nano will come out,and,no cam will work at this time!
Turok
Turok
Likes
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
#5
does,anyone know,the freqency,of channel 4 and 5,then i can try it over my openbox x 810 blindscan reveiver
in cam menu,i also see videogurard selectable
but,i dont know freqency,coz "normal "reveivers,only showing numbers,instead of names,on most sky channels,after search
P
papasmack
Likes
Open Box x-810 Receiver with the South Africa Multi-Choice satellite package
Kazakhstan
#6
Turok, I need the FT 300 updater for my Open Box X-810. If you have it, could you pass it along. I really would like to have it in English. I also have no user's manual. Would be great if you could help.
