Camos Satellite Dish on motorhome
milpol1
Teleco
Plymouth
OK here is the problem...................The system was working fine picking up all the stations I wanted, anyway, left the motorhome with grandson and he had the remote, came back a little bit later and nothing zilch, asked what had happened and he said that that he had been fiddling with the internal settings........ arghhhhhhhhhhhhhhhhhhhh.
I have looked everywhere trying to find out how to "reset" the system to no avail..............must get it sorted or I will have an expensive piece of metal on the top of the van. The sat dish I believe was about 2006/7 vintage, it is an enclosed dome.
Thanks in advance
Can you take a screenshot or type out the existing settings?
milpol1
Teleco
Plymouth
I will endevour to get the details tomorrow and post them here. Thanks
