Can I load a dragoncam module with my receiver
Likes
Visionic VN 4312
France
#1
I have a Worldsat Maestro CI box, when i put my dragon cam and fundcard 7 with predator 3.21 my receiver detect dragon cam but i haven't got a menu in order to load the dragoncam.How to do ? Thanks for your answers
Mickha
Likes
553
#2
Hi shredder,
if you haven't got a menu how do you know your receiver is detecting the Cam? Did you follow the instructions for loading you Dragon Cam:
Tune your receiver to a Free to Air Cahnnel.
Switch off your receiver.
Insert your programmed funcard 7 into your Dragon Cam, chip face up.
Switch on receiver.
Go to the Common interface menu on the receiver, and select the "Dragon Loader" module.
In the next menu, select "yes, Load module".
Now a menu appears indicating that loading is in progress. To see the actual progress percentage, select "refresh". There is no auto-refresh because some receivers had problems with that....
When loading is complete, a menu appears saying "Loading successful". REMOVE the loader card from the module, and switch off and turn back on the receiver.
I hope this helps.
Best wishes
Mickha
Likes
Visionic VN 4312
France
#3
Thanks you for your answers but I found my problem I need updating my cam
